markdutton
Backup failing on CCR v6.15
Tue Jul 29, 2014 12:30 pm
Hi All
I have a CCR 9 core on 6.15. It is in operation and working, but I can no longer create a backup. The password for the admin has reverted to blank also and won't save. I can't create a capture file with packet sniffer. It is as if the file system has become read only.
The exact error when I try to backup is
Couldn't make backup - action failed (6).
I am not seeing any errors in stores/disk, or anywhere else.
It is a major issue as it is a core router in a reasonably large network.
Any ideas? I have exported the text config and I am thinking I have to factore reset and restore that, but if I don't have to I would be very happy.
normis
Re: Backup failing on CCR v6.15
Tue Jul 29, 2014 12:39 pm
We have detected an issue and it will be fixed today in v6.18 later today. We will put an updated RC build on our website.
markdutton
Tue Jul 29, 2014 12:44 pm
OK Thanks Normis
Next problem though will be that I can't upgrade the router without netflash.
If I factory default, will I get access to the flash again? I have rebooted, but this did not help.
Is thre any way to get the flash writing without defaulting unit?
Mark
markdutton
Tue Jul 29, 2014 2:37 pm
OK. Update.
After a cold restart (power off), it has come up working again. We can run until the new firmware is out GA. It seems that this is a start up issue.
Users browsing this forum: Lizzardd, matxanh, shimal and 111 guests
