MUM Europe 2020
xphat
Weird LACP Issue
Tue Jul 29, 2014 10:45 pm
Hello all,
SO i'm trying to do a LACP Between a Mikrotik and the Switch Module of a Cisco 2851 Router to aggregate data between some ports.
Issue I am having here is that the Bonded Interface Comes Up However I am only getting Rx Traffic on One Interface but Tx Traffic on both interfaces.
SHO LACP NEIGHBOUR
Flags:  S - Device is requesting Slow LACPDUs
        F - Device is requesting Fast LACPDUs
        A - Device is in Active mode       P - Device is in Passive mode
Channel group 2 neighbors
Partner's information:
                  LACP port                        Oper    Port     Port
Port      Flags   Priority  Dev ID         Age     Key     Number   State
Fa1/0/44  SA      255       0060.e04a.6c03  20s    0x9     0x1      0x3D
Fa1/0/45  SA      255       0060.e04a.6c03  20s    0x9     0x2      0x3D
Bonding is setup like so:
0  R name="bond_Routed" mtu=1500 mac-address=00:60:E0:4A:6C:03 arp=enabled
      slaves=ether5 - Bonding Connection To Internet,ether6 - Bonding Connection
       To Internet
      mode=802.3ad primary=none link-monitoring=mii arp-interval=100ms
      arp-ip-targets="" mii-interval=100ms down-delay=0ms up-delay=0ms
      lacp-rate=30secs transmit-hash-policy=layer-2-and-3
This LACP is a Layer 3 Port Channel, However I have another group 1 that is on a switchport between the same two devices that works as expected.
Anyone ever encountered this before?
onnoossendrijver
Re: Weird LACP Issue
Tue Jul 29, 2014 11:11 pm
Can you tell me the layer 3 configuration of this part of the network?
If the Mikrotik only receives on 1 interface that's because the Cisco sends only on 1 interface :)
The Cisco is the problem here.
What is the hash policy on the Cisco?
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
xphat
Wed Jul 30, 2014 1:06 am
It is a /30 connection between the Cisco and the Router. Running OSPF for dynamic routing.
The transmit hash policy for the Cisco was the problem.
port-channel load-balance src-dst-ip
Fixed the Issue.
Thanks for the Direction. :)
joegoldman
Long time Member
Long time Member
Wed Jul 30, 2014 2:45 am
this is one problem with proper 802.3ad from what i mostly see - its a per-flow kind of load balance means at best you might get a 70/30 balance, and a single stream always only 1 link worth. Mikrotiks own balance-rr gives proper bonding in my eyes, yet to get Mikrotik + Cisco doing good proper load sharing+bonding. I still use it though as it does split it a bit, and lets me lose a port/cable in failrue without losing the whole link.
nz_monkey
Wed Jul 30, 2014 9:53 am
Yep problem is L2 hash on Cisco
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
onnoossendrijver
Wed Jul 30, 2014 12:36 pm
Balance-RR can give severe problems when packets arrive out-of-order.
nz_monkey
Wed Jul 30, 2014 3:08 pm
Correct thats why the most compatible combo is to use 802.3ad + L3/L4 Hash on the Mikrotik side, and the same on the remote side.
If the remote side does not support L3/L4 hash, then use L3 hash, or L2 hash and it will all work happily.
We have this running perfectly:
Mikrotik to Cisco
Mikrotik to Juniper
Mikrotik to Extreme
Mikrotik to HP
Splash
Mon Nov 27, 2017 7:09 pm
I know this post is a bit old :) but would anyone be able to provide a working solution for creating a LAG between a Mikrotik and a Juniper router that actually works?
I'm really struggling to use a CCR1009-8G-1S-1S+ with its 1 x 10g and 1 x 1g fibre ports in a LAG. Traffic flows over the 1g, but not on the 10g. 10g port is forced to 1g (with a 1g SFP) and part of a bonded interface.
No matter what I do, the Juniper just does not want to bring the sfp+ with the 1g interface up.
Does this work with this model CCR?
Mikrotik sees it as up, but I dont think the LACP packets are getting to the Juniper...
show lacp interfaces ae1
Aggregated interface: ae1
    LACP state:       Role   Exp   Def  Dist  Col  Syn  Aggr  Timeout  Activity
      ge-1/0/3       Actor    No    No   Yes  Yes  Yes   Yes     Slow    Active
      ge-1/0/3     Partner    No    No   Yes  Yes  Yes   Yes     Slow    Active
      ge-1/0/4       Actor    No   Yes    No   No   No   Yes     Slow    Active
      ge-1/0/4     Partner    No   Yes    No   No   No   Yes     Fast   Passive
    LACP protocol:        Receive State  Transmit State          Mux State
      ge-1/0/3                  Current   Slow periodic Collecting distributing
      ge-1/0/4                Defaulted   Fast periodic           Detached
show lacp statistics interfaces ae1
    LACP Statistics:       LACP Rx     LACP Tx   Unknown Rx   Illegal Rx
      ge-1/0/3                  29          48            0            0
      ge-1/0/4                   0         711            0            0
MTCNA, MTCRE, MTCINE, MTCTCE, MTCIPv6E, MTCUME
Users browsing this forum: Bing [Bot], luftenberg, oskarsk, ozairakhlaq, selimadn, TheSirStumfy and 124 guests
