mariush83
Losing Interface graphs after reboot
Tue Aug 05, 2014 10:07 am
Hi
Do you have any idea why my MT is loosing graph data after reboot?
ros code
[admin@MikroTik] /tool graphing> print
   store-every: 5min
  page-refresh: 300
[admin@MikroTik] /tool graphing interface> print
Flags: X - disabled
 #   INTERFACE     ALLOW-ADDRESS                                  STORE-ON-DISK
 0   all           192.168.88.0/24                                yes
[admin@MikroTik] /system routerboard> print
       routerboard: yes
             model: 2011UiAS-2HnD
     serial-number: 444A04E9417D
  current-firmware: 3.18
  upgrade-firmware: 3.18
It happened on previous software releases <6.18.
Is there anything else to be configured?
ronniee
Re: Losing Interface graphs after reboot
Tue Oct 18, 2016 3:14 pm
I need az USB stick to store graphs on it?
What i need to configure?
jarda
Wed Oct 19, 2016 11:28 am
What version do you have? Update to latest. Aren't you rebooting before the graphs are saved? Check the save interval...
Saving to other than local flash is not supported.
Lakis
Forum Veteran
Forum Veteran
Wed Oct 19, 2016 12:44 pm
This is old post - active again - Probably you don't need usb stick-not supported graphs don't use lot of space
if you are losing your graphs after reboot simply It may be related to your RB clock, just setup NTP client and put correct time zone
If NTP client is not adjust, after reboot your RB clock will be reset to default so this will affect your graphs.
Just giving my 2 cent.
Users browsing this forum: Baidu [Spider], ramirez and 67 guests
