bobertperry
Vlan Interfaces Disappearing
Sun Aug 17, 2014 5:47 pm
Help!
We had at least two vlans disappear last night!
* Nothing out of the ordinary shows up in the log or history.
* I can't add a new vlan interface with the same interface/vlan-id. I get the error message: "Couldn't add New Interface - already have such vlan (6)".
* This happened once before but it was an unimportant vlan. When it happened before I did reboot the router but to no avail.
* The IP on the router is still there. In winbox it's interface shows "unknown". It's pingable from my machine.
* Other IPs on that vlan are not accessible.
* Version 6.11 (x86)
Any Ideas?
CelticComms
Re: Vlan Interfaces Disappearing
Sun Aug 17, 2014 6:03 pm
Are you looking in Winbox or at the command line?
Interlynx | Networking and Information Security Consultants & Trainers | Email: routerlynx@gmail.com
BGP | EIGRP | OSPF | MPLS | Firewall | VPN | IPsec | Multicast | QOS | IPv4/6 | STP | VLAN | PON | AE | M2M | and more!
bobertperry
Sun Aug 17, 2014 6:31 pm
Winbox originally but it also doesn't show up in the command line.
[rob@Boman Router] /interface vlan> :put [ /interface vlan get [ /interface vlan f
ind where vlan-id=120 ]]
no such item
It also dosn't show up with just a /interface vlan print
CelticComms
Sun Aug 17, 2014 8:03 pm
I saw an odd behavior on VLANs on an earlier v6.xx at one point - I suggest that you update the ROS version and see if the problem disappears.
bobertperry
Sun Aug 17, 2014 8:07 pm
I'll try that but It will have to wait until early morning. I've routed the vlans/subnets though an intermediate router for now.
bobertperry
Mon Aug 18, 2014 2:13 pm
Upgrade did the trick. Thanks~
lz1dsb
Mon Aug 18, 2014 3:52 pm
I've had a situation with RouterOS v6.17 where almost all of my bridge interfaces were lost. A reboot of the device solved it, for now. It's kind of strange though, as some of the traffic was still flowing through the device. So I wonder... whether it will happen again ;)
bobertperry
Mon Aug 18, 2014 6:41 pm
Ugh, that's scary...
petrb
Fri Jan 19, 2018 10:55 am
Yes, the same situation at
RouterOS 6.34.6 na CCR1036-8G-2S+ FW:3.27
During making changes "ip route rules" all virtual interfaces simply disappear. No bridge, no vpls, no eoip. IP address assigned to this interface stay in the routing table with no assigned interface => but some traffic pass. Icmp echo to bridge interface pass. Newly created ip address is not listed in routing table. Reboot fix this state. Now is upgraded to 6.39.3 and 3.41. I will make some investigations about memory and look at capacitor health.
Did you read manual? .... What? .... Read the manual.
petrb
Sat Jan 20, 2018 6:34 pm
CPU stats from incident ..... one or two cpu cores goes up to 100%
https://ibb.co/n0vTWw
Users browsing this forum: Bing [Bot], didis81, eworm, gnommon, Ximi87 and 93 guests
