lz1dsb
How filter output in /ip firewall connection print
Tue Aug 26, 2014 2:56 pm
I know that there's a way to filter the print output of a command and I use this regularly in the /ip route print output.
But why it doesn't work on /ip firewall nat?
For example when I try to filter out only the connections from a particular source address - it does not work, I've got empty output. I use
/ip firewall connection print where src-address=x.x.x.x
I've just got an empty output like:
Flags: S - seen reply, A - assured
# PROTOCOL SRC-ADDRESS DST-ADDRESS TCP-STATE TIMEOUT
Am I missing something?
Kickoleg
Re: How filter output in /ip firewall connection print
Tue Aug 26, 2014 6:09 pm
How you can use this : /ip route print output ??????
MTCNA, MTCUME, MTCRE, MTCWE, MTCTCE certified
MrYan
Tue Aug 26, 2014 6:11 pm
/ip firewall connection print where src-address ~"x.x.x.x:" should work.
Matt.
lz1dsb
Tue Aug 26, 2014 6:38 pm
Matt.
Thank you Matt! Kudos for that.
Where can I find more info about the matching options? I'm also struggling with the ip route print output, as I have a full IP routing table and sometimes I need to filter based on AS Path attribute. I learned how I can do that filtering with dst-address and gateway, but still I need to filter even in greater details.
Also... filtering based on few matching patterns - is that possible? Can I also have different logical operators between the matching patterns?
chechito
Fri Dec 08, 2017 11:44 pm
thx for the tip, very usefull
beamzer
Sun Jul 22, 2018 12:02 pm
check out:
https://wiki.mikrotik.com/wiki/Manual:S ... _Operators
Ewald...
Users browsing this forum: No registered users and 10 guests
