lotnybartek
fetch: file "dyndns.checkip.html" downloaded
Thu Aug 28, 2014 10:41 pm
Hi there.
Since I upgraded my RB2011s to 6.19 I can see in my log:
UpdateDynDNS: username = xxxxxx
UpdateDynDNS: hostname = xxxxxxxxxxxxxxxxxxxxxxxxx
UpdateDynDNS: previousIP = xx.xx.xx.xx
UpdateDynDNS: currentIP = xx.xx.xx.xx
UpdateDynDNS: No dyndns update needed
This is a new entry which I did not see earlier.
I don't know if this is good or bad.
Can someone explain this one to me?
Kind Regards
Bart
jarda
Re: fetch: file "dyndns.checkip.html" downloaded
Thu Aug 28, 2014 11:34 pm
Seems you run some dynamic dns script. It should be intentional. This is not part of ros.
lotnybartek
Fri Aug 29, 2014 10:34 am
Yes, I run such script.
I was talking about BOLD entry:
I have not seen this entry before 6.19.
jarda
Fri Aug 29, 2014 10:39 am
Probably other not documented change in ros...
janisk
Fri Aug 29, 2014 4:23 pm
fetch received minor changes (that you noticed) all downloads will be logged to info topic.
lotnybartek
Tue Sep 02, 2014 1:20 pm
Thanks janisk. Simple as that.
biomann
Wed Oct 15, 2014 8:15 am
Is there some way to stop this? I am using fetch for my dyndns script ( i am using a 3g connection behind carrier grade nat,), but sadly fetch floods my log every two minutes.
tsul
Sat Oct 25, 2014 1:10 am
+1
SvZol
Tue Dec 09, 2014 10:22 am
I'm also need to stop this (maybe it some option in config for future releases?). Now a'm using ROS 6.23.
SaeedYa
Thu Feb 19, 2015 8:58 pm
I prefer not seeing fetch event, every time it tries to download any file
tsul
Mon Jul 06, 2015 7:03 pm
It would be great if MikroTik team added another new topic for this "fetch: ..." messages.
For example "info, files".
So that anyone can edit theirs logging rules to suppress these annoying log messages from fetch tool.
Or else how can someone filter that out?
jarda
Thu Jul 09, 2015 7:05 am
Exactly. I wonder why it is not configurable by this way.
SaeedYa
Sun Aug 02, 2015 6:47 pm
You can use ip cloud for this purpose.
jarda
Tue Aug 04, 2015 12:56 am
Ip cloud is not able to replace full-featured ddns service. Anyway, this topic is about logging, have you noticed that?
Users browsing this forum: Bing [Bot], bpwl, hgoertz, Sob and 132 guests
