MUM Europe 2020
cylent
slow internet
Wed Jun 07, 2006 8:14 am
My Interent Service Provider says my Router is slowing my internet down.
Has anybody else heard this?
What info do i need to provide so we can diagnose this?
sergejs
Wed Jun 07, 2006 9:42 am
cylent, more information required about 'slowing my internet'.
Probably, you have queue,firewall configuration, that limit/block certain traffic.
cylent
Wed Jun 07, 2006 9:47 am
i realize i need more information.
i am still new to RouterOS and would like you to tell me what info you want to see and i'll happily provide it.
sergejs
Wed Jun 07, 2006 10:13 am
cylent, you have to give us more information about your current problem.
(Why your provider told that "Router is slowing my internet down ").
cylent
Wed Jun 07, 2006 10:48 am
well when i disconnected the router and connected my laptop directly to my linkstar (satellite modem) i noticed pages loaded faster and my isp guy said he got a better ping and such
sergejs
Wed Jun 07, 2006 11:14 am
Disable queues, firewall rules on router and try to check how it will work.
If connection will be good (suitable).
Try to enable rules one by one in order to find incorrect configuration rule.
cylent
Wed Jun 07, 2006 5:36 pm
in Queues I have the following Simple Queue which i cant disable.
[admin@grnzne-inet] queue> simple
[admin@grnzne-inet] queue simple> print
 0  D name="<hotspot1>" dst-address=0.0.0.0/0 interface=ether2 parent=none
      direction=both priority=8 queue=hotspot-default/hotspot-default
      limit-at=0/0 max-limit=0/0 total-queue=default-small
and in Firewall -- NAT i have the following:
[admin@grnzne-inet] ip firewall nat> print
 0   ;;; masquerade hotspot network
     chain=srcnat src-address=192.168.0.0/24 action=masquerade
 1 X ;;; masquerade hotspot network
 2 X chain=dstnat in-interface=ether2 dst-address=0.0.0.80 protocol=tcp
     action=redirect to-ports=8080
 3   ;;; ;;; intercept all DNS requests
     chain=dstnat protocol=udp dst-port=53 action=dst-nat
     to-addresses=192.168.0.1 to-ports=0-65535
 4   ;;; ;;; Transparent Proxy
     chain=dstnat dst-address=192.168.0.1 protocol=tcp dst-port=80
     action=redirect to-ports=3128
what else is there that you care to see?
djape
Thu Jun 08, 2006 9:48 am
It's not a router issue!
It's a problem with concurent tcp connections you can use over satellite.
When you disconnect router you also kill established tcp connections (free) and when you connect laptop your net is going fast.
These satellite links are not ment to be used for a lot of users, just few.
Go to ip firewall connection tracking and count how many established connections you have.
You can help a lot if you reduce established connections timeout to 1hour or 30 minutes and you'll have a little improvement, but not much.
There is no router solution for your situation, sorry.
Cheers...
I drink like a pirate and smoke like a hippie...
cylent
Thu Jun 08, 2006 9:58 am
i dont understand what you mean.
Users browsing this forum: aeiouy, Google Feedfetcher, MSN [Bot], sergeykozlobaev and 110 guests
