Trekkie
Troubleshooting L2TP / IPSEC Tunnel
Mon Sep 08, 2014 8:56 pm
I'm attempting to set up a router level VPN connection to an L2TP/IPSEC solution.
The service is from IVPN, and they offer L2TP / IPSEC connection. It works fine if I use the built in VPN client on my host.
I have the certificate, key, and it's loaded. I enable L2TP and it connects, I see a remote peer on IPSEC.
I turned on extended logging for L2TP and this is the output:
100 items
 	 	#	Time	Buffer	Topics	Message
0	Sep/08/2014 13:39:40	memory	dhcp, info	dhcp1 deassigned 172.16.0.61 from D4:4B:5E:9D:4E:84
1	Sep/08/2014 13:39:40	memory	dhcp, info	dhcp1 assigned 172.16.0.61 to D4:4B:5E:9D:4E:84
2	Sep/08/2014 13:47:45	memory	system, info, account	user admin logged in from 172.16.0.50 via web
3	Sep/08/2014 13:48:34	memory	system, info	log rule added by admin
4	Sep/08/2014 13:48:38	memory	system, info	device changed by admin
5	Sep/08/2014 13:48:38	memory	l2tp, ppp, info	l2tp-out1: initializing...
6	Sep/08/2014 13:48:38	memory	l2tp, ppp, debug	l2tp-out1: IPCP demandUp
7	Sep/08/2014 13:48:38	memory	l2tp, ppp, debug	l2tp-out1: IPV6CP demandUp
8	Sep/08/2014 13:48:38	memory	l2tp, ppp, debug	l2tp-out1: MPLSCP demandUp
9	Sep/08/2014 13:48:38	memory	l2tp, ppp, info	l2tp-out1: waiting for packets...
10	Sep/08/2014 13:49:05	memory	system, info	nat rule changed by admin
11	Sep/08/2014 13:49:09	memory	system, info	nat rule changed by admin
12	Sep/08/2014 13:49:13	memory	system, info	nat rule changed by admin
13	Sep/08/2014 13:49:32	memory	l2tp, ppp, info	l2tp-out1: connecting...
14	Sep/08/2014 13:49:32	memory	l2tp, debug	tunnel 1 entering state: wait-ctl-reply
15	Sep/08/2014 13:49:32	memory	l2tp, debug, packet	sent control message to 107.191.34.155:1701
16	Sep/08/2014 13:49:32	memory	l2tp, debug, packet	 tunnel-id=0, session-id=0, ns=0, nr=0
17	Sep/08/2014 13:49:32	memory	l2tp, debug, packet	 (M) Message-Type=SCCRQ
18	Sep/08/2014 13:49:32	memory	l2tp, debug, packet	 (M) Protocol-Version=0x01:00
19	Sep/08/2014 13:49:32	memory	l2tp, debug, packet	 (M) Framing-Capabilities=0x1
20	Sep/08/2014 13:49:32	memory	l2tp, debug, packet	 (M) Bearer-Capabilities=0x0
21	Sep/08/2014 13:49:32	memory	l2tp, debug, packet	 Firmware-Revision=0x1
22	Sep/08/2014 13:49:32	memory	l2tp, debug, packet	 (M) Host-Name="galaxy"
23	Sep/08/2014 13:49:32	memory	l2tp, debug, packet	 Vendor-Name="MikroTik"
24	Sep/08/2014 13:49:32	memory	l2tp, debug, packet	 (M) Assigned-Tunnel-ID=1
25	Sep/08/2014 13:49:32	memory	l2tp, debug, packet	 (M) Receive-Window-Size=4
26	Sep/08/2014 13:49:33	memory	l2tp, debug, packet	sent control message to 107.191.34.155:1701
27	Sep/08/2014 13:49:33	memory	l2tp, debug, packet	 tunnel-id=0, session-id=0, ns=0, nr=0
28	Sep/08/2014 13:49:33	memory	l2tp, debug, packet	 (M) Message-Type=SCCRQ
29	Sep/08/2014 13:49:33	memory	l2tp, debug, packet	 (M) Protocol-Version=0x01:00
30	Sep/08/2014 13:49:33	memory	l2tp, debug, packet	 (M) Framing-Capabilities=0x1
31	Sep/08/2014 13:49:33	memory	l2tp, debug, packet	 (M) Bearer-Capabilities=0x0
32	Sep/08/2014 13:49:33	memory	l2tp, debug, packet	 Firmware-Revision=0x1
33	Sep/08/2014 13:49:33	memory	l2tp, debug, packet	 (M) Host-Name="galaxy"
34	Sep/08/2014 13:49:33	memory	l2tp, debug, packet	 Vendor-Name="MikroTik"
35	Sep/08/2014 13:49:33	memory	l2tp, debug, packet	 (M) Assigned-Tunnel-ID=1
36	Sep/08/2014 13:49:33	memory	l2tp, debug, packet	 (M) Receive-Window-Size=4
37	Sep/08/2014 13:49:34	memory	l2tp, debug, packet	sent control message to 107.191.34.155:1701
38	Sep/08/2014 13:49:34	memory	l2tp, debug, packet	 tunnel-id=0, session-id=0, ns=0, nr=0
39	Sep/08/2014 13:49:34	memory	l2tp, debug, packet	 (M) Message-Type=SCCRQ
40	Sep/08/2014 13:49:34	memory	l2tp, debug, packet	 (M) Protocol-Version=0x01:00
41	Sep/08/2014 13:49:34	memory	l2tp, debug, packet	 (M) Framing-Capabilities=0x1
42	Sep/08/2014 13:49:34	memory	l2tp, debug, packet	 (M) Bearer-Capabilities=0x0
43	Sep/08/2014 13:49:34	memory	l2tp, debug, packet	 Firmware-Revision=0x1
44	Sep/08/2014 13:49:34	memory	l2tp, debug, packet	 (M) Host-Name="galaxy"
45	Sep/08/2014 13:49:34	memory	l2tp, debug, packet	 Vendor-Name="MikroTik"
46	Sep/08/2014 13:49:34	memory	l2tp, debug, packet	 (M) Assigned-Tunnel-ID=1
47	Sep/08/2014 13:49:34	memory	l2tp, debug, packet	 (M) Receive-Window-Size=4
48	Sep/08/2014 13:49:36	memory	l2tp, debug, packet	sent control message to 107.191.34.155:1701
49	Sep/08/2014 13:49:36	memory	l2tp, debug, packet	 tunnel-id=0, session-id=0, ns=0, nr=0
50	Sep/08/2014 13:49:36	memory	l2tp, debug, packet	 (M) Message-Type=SCCRQ
51	Sep/08/2014 13:49:36	memory	l2tp, debug, packet	 (M) Protocol-Version=0x01:00
52	Sep/08/2014 13:49:36	memory	l2tp, debug, packet	 (M) Framing-Capabilities=0x1
53	Sep/08/2014 13:49:36	memory	l2tp, debug, packet	 (M) Bearer-Capabilities=0x0
54	Sep/08/2014 13:49:36	memory	l2tp, debug, packet	 Firmware-Revision=0x1
55	Sep/08/2014 13:49:36	memory	l2tp, debug, packet	 (M) Host-Name="galaxy"
56	Sep/08/2014 13:49:36	memory	l2tp, debug, packet	 Vendor-Name="MikroTik"
57	Sep/08/2014 13:49:36	memory	l2tp, debug, packet	 (M) Assigned-Tunnel-ID=1
58	Sep/08/2014 13:49:36	memory	l2tp, debug, packet	 (M) Receive-Window-Size=4
59	Sep/08/2014 13:49:40	memory	l2tp, debug, packet	sent control message to 107.191.34.155:1701
60	Sep/08/2014 13:49:40	memory	l2tp, debug, packet	 tunnel-id=0, session-id=0, ns=0, nr=0
61	Sep/08/2014 13:49:40	memory	l2tp, debug, packet	 (M) Message-Type=SCCRQ
62	Sep/08/2014 13:49:40	memory	l2tp, debug, packet	 (M) Protocol-Version=0x01:00
63	Sep/08/2014 13:49:40	memory	l2tp, debug, packet	 (M) Framing-Capabilities=0x1
64	Sep/08/2014 13:49:40	memory	l2tp, debug, packet	 (M) Bearer-Capabilities=0x0
65	Sep/08/2014 13:49:40	memory	l2tp, debug, packet	 Firmware-Revision=0x1
66	Sep/08/2014 13:49:40	memory	l2tp, debug, packet	 (M) Host-Name="galaxy"
67	Sep/08/2014 13:49:40	memory	l2tp, debug, packet	 Vendor-Name="MikroTik"
68	Sep/08/2014 13:49:40	memory	l2tp, debug, packet	 (M) Assigned-Tunnel-ID=1
69	Sep/08/2014 13:49:40	memory	l2tp, debug, packet	 (M) Receive-Window-Size=4
70	Sep/08/2014 13:49:48	memory	l2tp, debug, packet	sent control message to 107.191.34.155:1701
71	Sep/08/2014 13:49:48	memory	l2tp, debug, packet	 tunnel-id=0, session-id=0, ns=0, nr=0
72	Sep/08/2014 13:49:48	memory	l2tp, debug, packet	 (M) Message-Type=SCCRQ
73	Sep/08/2014 13:49:48	memory	l2tp, debug, packet	 (M) Protocol-Version=0x01:00
74	Sep/08/2014 13:49:48	memory	l2tp, debug, packet	 (M) Framing-Capabilities=0x1
75	Sep/08/2014 13:49:48	memory	l2tp, debug, packet	 (M) Bearer-Capabilities=0x0
76	Sep/08/2014 13:49:48	memory	l2tp, debug, packet	 Firmware-Revision=0x1
77	Sep/08/2014 13:49:48	memory	l2tp, debug, packet	 (M) Host-Name="galaxy"
78	Sep/08/2014 13:49:48	memory	l2tp, debug, packet	 Vendor-Name="MikroTik"
79	Sep/08/2014 13:49:48	memory	l2tp, debug, packet	 (M) Assigned-Tunnel-ID=1
80	Sep/08/2014 13:49:48	memory	l2tp, debug, packet	 (M) Receive-Window-Size=4
81	Sep/08/2014 13:49:49	memory	system, info, account	user admin logged in from 172.16.0.50 via web
82	Sep/08/2014 13:49:56	memory	l2tp, debug	tunnel 1 received no replies, disconnecting
83	Sep/08/2014 13:49:56	memory	l2tp, debug	tunnel 1 entering state: dead
84	Sep/08/2014 13:49:56	memory	l2tp, debug	session 1 entering state: dead
85	Sep/08/2014 13:49:56	memory	l2tp, ppp, info	l2tp-out1: terminating... - session closed
86	Sep/08/2014 13:49:56	memory	l2tp, ppp, debug	l2tp-out1: LCP lowerdown
87	Sep/08/2014 13:49:56	memory	l2tp, ppp, debug	l2tp-out1: LCP down event in initial state
88	Sep/08/2014 13:49:56	memory	l2tp, ppp, info	l2tp-out1: disconnected
89	Sep/08/2014 13:49:56	memory	l2tp, ppp, info	l2tp-out1: initializing...
90	Sep/08/2014 13:49:56	memory	l2tp, ppp, debug	l2tp-out1: IPCP demandUp
91	Sep/08/2014 13:49:56	memory	l2tp, ppp, debug	l2tp-out1: IPV6CP demandUp
92	Sep/08/2014 13:49:56	memory	l2tp, ppp, debug	l2tp-out1: MPLSCP demandUp
93	Sep/08/2014 13:49:56	memory	l2tp, ppp, info	l2tp-out1: waiting for packets...
94	Sep/08/2014 13:50:13	memory	system, info	nat rule changed by admin
95	Sep/08/2014 13:50:18	memory	l2tp, ppp, info	l2tp-out1: terminating...
96	Sep/08/2014 13:50:18	memory	l2tp, ppp, debug	l2tp-out1: LCP lowerdown
97	Sep/08/2014 13:50:18	memory	l2tp, ppp, debug	l2tp-out1: LCP down event in initial state
98	Sep/08/2014 13:50:18	memory	l2tp, ppp, info	l2tp-out1: disabled
99	Sep/08/2014 13:50:18	memory	system, info	device changed by admin
What I do is change my NAT to force everything through the l2tp interface and the instant I do that, traffic halts and the l2tp link starts flapping up and down.
Any other logging I should turn on to trouble shoot?
IPSEC Setup for 'peer'
Flags: X - disabled, D - dynamic
 0    address=0.0.0.0/0 local-address=0.0.0.0 passive=no port=500
      auth-method=pre-shared-key secret="notthatdumb" generate-policy=no
      policy-group=default exchange-mode=main send-initial-contact=yes
      nat-traversal=no proposal-check=obey hash-algorithm=sha1
      enc-algorithm=des,3des,aes-128,aes-192,aes-256,blowfish,camellia-128,
              camellia-192,camellia-256
      dh-group=modp2048 lifetime=1d lifebytes=0 dpd-interval=2m
      dpd-maximum-failures=5
my l2tp setup
name="l2tp-out1" max-mtu=1400 max-mru=1400 mrru=disabled
      connect-to=ipaddress user="nope"
      password="haha" profile=default-encryption
      keepalive-timeout=disabled add-default-route=yes
      default-route-distance=1 dial-on-demand=yes
      allow=pap,chap,mschap1,mschap2
I can show the firewall rules if you like, but they're a basic pre-route tag, a masq that routes all packets out the lt2p-out1.
Thanks.
Users browsing this forum: Bing [Bot] and 73 guests
