MikroTikFan
How to login to default hotspot
Sat Sep 27, 2014 10:45 pm
Please help me how to login to hotspot.
By my mistake I have add new bridged hotspot without setting new user and password.
I can't login to Webfig because hotspot ask me for user and password.
My webfig login and password don't work with hotspot.
What can I do not to reset my whole router and lose configuration ?
Is there any way to login to default user/pass to hotspot?
SurferTim
Re: How to login to default hotspot
Sat Sep 27, 2014 11:32 pm
When you set up the first hotspot on that router, it asks for a user and password for a "default" user. What did you enter there? Same as the login for the router?
MikroTikFan
Sat Sep 27, 2014 11:48 pm
By setting first hot spot (this is first) I didn't set up user and password ;-(
After apply this settings of this first hot spot I just got login page to hotspot, and I don't know user/pass
Is there any default user/pass ?
So is there any chance to login without resetting whole config from the router ?
SurferTim
Sun Sep 28, 2014 3:36 am
If you used "/ip hotspot setup", the default user and password are the last prompts. I don't see how you missed it.
The rest I guess depends on your WAN interface. That shouldn't be on the hotspot. How strong is your firewall on it?
Does the device have a serial port? If so, get a null modem cable, login there, and disable the hotspot.
mikrottik
Fri Feb 03, 2017 3:44 pm
Hi Mikrotikfan.
I'm experiencing this same issue. I created hotspot on a bridge without setting the password and username. Now I can't login. How did you resolve the issue?
arturportella
Fri Feb 03, 2017 6:03 pm
Are you still able to connect to the router through MAC or IP using winbox -> Neighbors?
Artur Portella - Technical Manager @ Rmontan Tecnologia / BRAZIL
MTCNA - MTCRE - MTCINE
mikrottik
Mon Feb 06, 2017 12:56 pm
No, I can no longer connect through winbox as well. I assume the router has shut out all entry until I login to hotspot.
mikrottik
Mon Feb 06, 2017 1:49 pm
Oh thanks a lot. It worked and I'm in the router now. (winbox>neighbours)
omid1368
Sat Jul 08, 2017 8:21 am
hi, i take this mistake too, but i can'nt access modem via neighbors . i give error could not connect to ...
what can i do, except reseting router?
Limbrey
Wed Aug 16, 2017 5:17 pm
I have this issue too. Blew me away. Thought I'd look at the hotspot feature, but got booted from webfig and can't login with my webfig admin details any more. There must be a default user/password???
mikedefieslife
Fri Feb 14, 2020 7:49 pm
Same problem here.
As soon as you enable hotspot you are booted out of the webconfig with no ability to log back in or access anything.
Winbox is no good as I’m on a mac.
offlinejke
Mon May 11, 2020 11:38 am
Crap!
I'm the same issue. And can't connect via neighbors. Any idea how to login devise without reset?
mahsanamin
Sat Jun 13, 2020 12:09 am
:( Exact same problem, as soon as I selected the Bridge I am kicked out of webfig console :( and I am also on MAC.
Users browsing this forum: antant and 85 guests
