shephajona
OpenDaylight and Openflow help v6.19
Mon Sep 29, 2014 4:18 am
(I hope this is in the right place)
Hello to anyone who can help some tertiary students with an opendaylight problem
We are currently running into issues using OpenDaylight and the openflow protocol (1.0) with a MikroTik routerboard running RouterOS v6.19
We are trying to adapt a load balancing application we have found from here: http://www.frank-durr.de/?p=126 and are having issues when the application tries to write the flows to the routerboards.
The routerboards return the error in opendaylight:
OFPET_FLOW_MOD_FAILED OFPFMFC_ALL_TABLES_FULL
The thing is, there are no flows in the flow table that we can see in the routerboard and as a result of this error nothing is written into the flow tables at all meaning our load balancing experiment isn’t working.
Any help would be greatly appreciated, thanks
Paxy
Re: OpenDaylight and Openflow
Tue Sep 01, 2015 12:07 pm
Same issue with 6.31.
When I try to insert flow that change Network layer addresses (src or dst IP) getting message OFPET_FLOW_MOD_FAILED OFPFMFC_ALL_TABLES_FULL.
Same action with OpenVStiwtch works correctly.
mrz
Re: OpenDaylight and Openflow help v6.19
Wed Sep 02, 2015 12:59 pm
Currently OFPAT_SET_NW_SRC, OFPAT_SET_NW_DST actions are not supported.
andrewmoses
Mon Jan 18, 2016 2:51 pm
I'm trying to implement openflow protocol. I have routerboard rb750gl with routeros 6.32.3. To be frank I don't know where to start. I have tested my custom loadbalancing algo with pox controller in mininet. I trying to implement the same using the routerboard. thankyou in advance.
Users browsing this forum: Google [Bot], joshfinlay, kirshnabneha and 124 guests
