kazim
Bandwidth Compression between Mikrotik Routers
Tue Sep 30, 2014 3:28 pm
hello every one,
I have 30 Mb link in our office and internet is very expensive here. Now i want buy internet in other country like 100 Mb and make vpn tunnel between my Office Mikrotik and remote country Mikrotik and want compress the all the internet data.
Is it possible or not ? if possible then kindly put the configuration
I am using RB 1200 and remote side CCR-1036
Kadafi
Re: Bandwidth Compression between Mikrotik Routers
Tue Sep 30, 2014 4:00 pm
Use vpn with compression?
kazim
Tue Sep 30, 2014 5:30 pm
if you have configuration link kindly provide me. i could not found the configuration
reinerotto
Thu Oct 02, 2014 10:11 am
For a serious solution, you should
- install local PC+squid cache as a proxy
- use some type of ad-blocker (DNS-based) to avoid download of adverts to local PC
- install remote PC + compression software (ziproxy)
- use remote PC as a parent proxy for local squid
Works only for http, but might give you > 50% bandwidth savings.
Users browsing this forum: ahmad201020, alber, Google [Bot], ichihaifu, Majestic-12 [Bot] and 114 guests
