MUM Europe 2020
patrickmkt
action=del-src-from-address-list
Sat Oct 04, 2014 7:34 am
There are action=add-src-to-address-list and action=add-dest-to-address-list in NAT, Mangle and Filter.
How can I remove an address from a list as an action too?
Wouldn't it be nice to have also action=del-src-from-address-list and action=del-dest-from-address-list?
joegoldman
Long time Member
Long time Member
Re: action=del-src-from-address-list
Sat Oct 04, 2014 9:33 am
explain the purpose of which you want it and you should be able to achieve it with other firewall rules in combination.
Most importantly - add-src can have timeout so it auto-removes after a time.
patrickmkt
Sat Oct 04, 2014 6:46 pm
I am already using the time out option, however I was considering using some port knocking scenario to shut down access in addition to open them.
sejtam
Mon Feb 09, 2015 1:39 pm
Yes, I think this would be useful for port-knocking, or when detecting that a system outside has successfully established a connection (logged in), it can be removed from the blacklist.
I do think it can be worked aorund by instead adding the address to a whitelist (and then possibly having a script come around every x minutes checking the whitelists and deleting the whitelisted entries from the blacklists). But that would be much more complicated and likely error prone
Users browsing this forum: No registered users and 158 guests
