fronczek
WARNING: 6.20 upgrade bricked my CCR1036
Mon Oct 06, 2014 3:33 am
As in the subject: Upgrading CCR1036-12G-4S from 6.18 to 6.20 completely bricked the router - had to NetInstall all over again.
PS. SNMP on tile/ccr still not working as mentioned on:
[Ticket#2014051966000021] ROSv6.13 (tile) and
[Ticket#2014092066000289] CCR broken SNMP
Best regards,
Artur
sergejs
Re: WARNING: 6.20 upgrade bricked my CCR1036
Wed Oct 08, 2014 9:40 am
bricked the router
more detailed information about is required.
At least console output from CCR router after upgrade will handy.
fronczek
Wed Oct 08, 2014 10:08 am
Sorry, I was so mad that I forgot to make photos for you...
The last I remember was the loop: 'kernel load failed' (or something similar) >> reboot...
PS. NetInstall and restore from .backup also failed...
It stucked at another loop: kernel load >> starting services >> login screen (0,5 - 1 second) >> reboot...
At the end I had to restore from 'export compact' rsc backup file...
sergejs
Wed Oct 08, 2014 12:10 pm
Thank you for the report.
As currently this is the only report, it would be great to get any information from somebody who had similar issues, console output will be great.
scampbell
Trainer
Trainer
Thu Oct 09, 2014 9:23 am
I have received reports of a similar issue with an RB1100AHx2 being upgraded from RoS 5.26. Recovered successfully via serial and Netinstall ok.
drusha
Sun Oct 19, 2014 5:57 pm
6.14 to 6.20 upgrade bricked my sxt5lite as well. Is there a way to revert it?
upd: false alarm. it just take a huge while to come back online :D
Users browsing this forum: alex32c, andya, bpwl, Darmach, FridrichMein, Majestic-12 [Bot], mrmut, SiB, svmk, Tobei and 60 guests
