MUM Europe 2020
ahlai
the value is so large
Sun Jun 11, 2006 4:19 pm
Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.0.1: bytes=32 time=410ms TTL=64
Reply from 192.168.0.1: bytes=32 time=488ms TTL=64
Reply from 192.168.0.1: bytes=32 time=226ms TTL=64
Reply from 192.168.0.1: bytes=32 time=333ms TTL=64
Ping statistics for 192.168.0.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 226ms, Maximum = 488ms, Average = 364ms
There are only six computer in our lan,the pc which is installed router os hardware list:cpu c666, memory 192M
DirectWireless
Mon Jun 12, 2006 8:39 am
Nobody seems to have chimed in to help. You say there's 6 computers, most likely connected by a hub or switch. You need to do that ping from all 6 computers and compare. If all 6 have the same problem, it is most likely a switch or router problem. If you bypass the switch and plug direct into the router with a crossover cable you can eliminate the switch. Beyond that, I would watch system resources on your router (CPU Load) and see if it is high (80-100) or low (0-20) while pinging. You may have a bad cable or bad network card in your router.
Try those things, if the first test (ping from all 6) nets only 1 computer as a slow pinger, then you should check that computer specifically, and try changing the port you are plugging into on the switch. It could also be a virus on your network, that's always something to check.
djape
Re: the value is so large
Mon Jun 12, 2006 12:40 pm
cpu c666
I think it's all about 666 number :lol:
I drink like a pirate and smoke like a hippie...
Users browsing this forum: CZFan, Google [Bot] and 120 guests
