eduardi
IOS8 Insue Iphone Login
Thu Oct 09, 2014 11:52 pm
Hello, i update 2 iphones to IOS8 and don´t have more the login page,
i have the same problem in IOS7 , and resolved:
Walled Garden Ip Entry:
apple.com
captive.apple.com
ess.apple.com
gps.apple.com
init-p01md.apple.com
static.ess.apple.com
http://www.airport.us
http://www.appleiphonecell.com
http://www.ibook.info
http://www.itools.info
http://www.thinkdifferent.us
for IOS8 have more?????????????????
bajodel
Long time Member
Long time Member
Re: IOS8 Insue Iphone Login
Tue Oct 14, 2014 2:43 am
try to disable the wifi auto-login feature on ios8
anyway.. I'm starting to really hate those stupid Apple "features", they don't help users ..and make us crazy!
normis
Tue Oct 14, 2014 9:45 am
why do you put those things in walled garden? this will make hotspot not work.
apple checks those sites, and if it detects hotspot, login page is opened. if you put them in walled garden, iphone thinks that you have internet, and doesn't open login.
uldis
Tue Oct 14, 2014 1:42 pm
another suggestion is if you use DNS name in the Hotspot configuration then if you use just name for example, company, then you need to ad domain, for example, company.com
ditonet
Forum Veteran
Forum Veteran
Tue Oct 14, 2014 1:51 pm
Maybe he did this, because MT Wiki suggest this:
http://wiki.mikrotik.com/wiki/Manual:Cu ... r_override
Regards,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
normis
Tue Oct 14, 2014 1:56 pm
Regards,
do this only if you know what you are doing and why :) the manual gives this example for people who do not want to see the login page, because they need the user to manually open browser and do something
ditonet
Forum Veteran
Forum Veteran
Tue Oct 14, 2014 3:27 pm
This is general life advice :D
But seriously, eduardi's post shows that he probably follows mentioned above Wiki article.
Regards,
normis
Tue Oct 14, 2014 3:34 pm
So please remove these entries and see if it works :)
ditonet
Forum Veteran
Forum Veteran
Tue Oct 14, 2014 4:14 pm
I don't need to remove them, because they don't exist in my hotspots.
But I agree, user eduardi should remove them.
Regards,
eduardi
Wed Oct 22, 2014 1:06 pm
Hello many thanks for replys, sorry only see the replys today.
my hotspot dns :hotspot.1234.local
i have many apple device in my newtork, i have macbook only acess the login page, if i put the Walled Garden list.
i try all, in IOS 7, and only solved the problem with Walled Garden list.
today later i try disable all Walled Garden to test IOS8
FrancisMartin
Wed Oct 22, 2014 2:44 pm
Hello there,
I am Eduardi's friend, using the same network and also having the same problem. i only updated my ipad yesterday with the ios 8.1 (i was using ios 7.1.2 without any kind of problem with our network) and for my surprise this was the result...Blank page instead of the login one. Let's see if we can figure out how to solve this problem...
Cheers.
bajodel
Long time Member
Long time Member
Wed Oct 22, 2014 7:15 pm
I've solved similar problem editing "xxxx.yyyy.local" to a FQDN; I'm still asking myself 'why' ..but it works now! ;-)
ditonet
Forum Veteran
Forum Veteran
Wed Oct 22, 2014 11:42 pm
bajodel is right, something is wrong with '.local' domain and Apple devices.
Regards,
eduardi
Thu Oct 23, 2014 1:19 am
solved
many thanks to all,
change hotspot.1234.local
to hotspot.1234.pt
and work fine, no more Walled Garden list.
many, many thanks :)
ronniett
Sat Sep 19, 2015 2:56 pm
im new mikrotik user.
Where can i change dns hotspot.1234.local to hotspot.1234.pt
Thank You.
Users browsing this forum: armpogart, Bambie, h3ll1, inteq, sindy and 66 guests
