yuridee
(answered) New?! RBFTC11
Thu Oct 16, 2014 4:14 am
http://routerboard.com/RBFTC11
wondering about specs: transparent, switch, vlan-tagging, etc.
All the best,
Y
normis
Re: New?! RBFTC11
Thu Oct 16, 2014 9:14 am
It has no "features" since it is simply an adapter (converter). Plug in fiber, plug in ethernet, and it connects.
niktmn
Re: New?! RBFTC11
Thu Oct 23, 2014 10:27 am
Does it support 1000Base-T?
normis
Re: New?! RBFTC11
Fri Oct 24, 2014 10:50 am
Yes, It does
russman
Re: New?! RBFTC11
Mon Oct 27, 2014 9:26 pm
I'd love to see a version that offers POE output and an AC bus terminal. That would allow for remote radio hookups without the need for additional outdoor enclosures.
yuridee
Re: New?! RBFTC11
Tue Nov 04, 2014 4:56 am
Hi Normis,
Sorry to bother you, but would like to know for sure that VLAN tagging can go through and when its going to be available?
Thank you,
Yuri
adrcomms
Re: New?! RBFTC11
Mon Mar 02, 2015 8:22 pm
Microtik staff
Will the SFP slot support any SFP device? If so will it support the Finisar GPON stick? this could be a break through in the way i deploy my be FTTH GPON network.
http://www.finisar.com/products/optical-modules/pon
https://www.youtube.com/watch?v=3ELISum9mSI
Adrian
InoX
Re: New?! RBFTC11
Mon Mar 02, 2015 8:30 pm
Supports 1.25G 1000Base-X fiber to FE/GigE copper
Read the pdf.
adrcomms
Re: New?! RBFTC11
Tue Mar 03, 2015 10:35 am
Thanks for the answer. As the Finisar Gpon stick is a true gpon to sfp ethernet then what your saying is that the driver onboard should should? Or does that SFP device have to be a microtik SFP ? or can you put any SFP device in the FTC i.e cisco, HP etc.
Adrian
krisjanis
Re: New?! RBFTC11
Tue Mar 03, 2015 11:02 am
1. There are no drivers required for SFP modules.
2. In our device there is no SFP vendor lock in place, so other vendor SFP can be used.
3. If the module is made as advertised, then it should work in any device with SFP interface that meets the required standards on module host side.
adrcomms
Re: New?! RBFTC11
Tue Mar 03, 2015 2:07 pm
Thats great news, so even in a CRC36 it should work? That makes Microtik Gpon compatible
:D Adrian
mmv
Trainer
Trainer
Re: New?! RBFTC11
Mon Mar 09, 2015 2:54 pm
It interesting. But AFAIK, PON require configuring abonent's parameters.
Or MAC address is enough and time sloth is auto configured?
Somebody tried this modules?
Mikhail Moskalev
yuridee
Re: New?! RBFTC11
Wed Apr 01, 2015 3:14 am
Finally I've got one, tested. Like Normis said, fibre on one side and rj-45 on the other. Everything i've tested works just like using straight through cable
taduikis
Re: (answered) New?! RBFTC11
Sun Apr 26, 2015 6:47 pm
How about these Finisar G(E)PON SFPs? Anyone tried them in FTC11?
Users browsing this forum: No registered users and 87 guests
