jarda
Feature request: Netinstall on all ports
Tue Oct 28, 2014 8:43 pm
Please,
enable the netinstall on all ports for devices having more than one ethernet port. In case only one port at once can be in netinstall mode, let it be the first port that reports link-up status just before the netinstall can begin (the first physically connected port).
Reason: Sometimes the port that is the only one usable port of the device to perform netinstall is broken so there is no other option how to make netinstall (mainly for devices without serial port).
I expect that it could be done by small routerboot modification. Hopefully.
Thank you in advance.
jarda
Re: Feature request: Netinstall on all ports
Tue Nov 04, 2014 6:34 pm
None sees this useful?
letabawireless
Mon Nov 10, 2014 9:32 am
Yes please Mikrotik !
pizzulicchio
Thu Nov 20, 2014 6:08 pm
i have just written to mikrotik for this request some years ago...
i have lost an rb800 for this... ether 1 damaged , deleted routeros and no net install...
friction
Sat Nov 22, 2014 6:18 pm
I can see the usefulness of allowing this on additional, if not all, ports.
+1!
I am not a complete idiot, some parts are missing. [CCNA Sec / CCNP / LPIC-1]
guipoletto
Mon Nov 24, 2014 5:39 pm
You can install using a Serial cable. In RouterBOOT menu, go to Firmware Upgrade >> Serial (Xmodem), then, in telnet, select "Send File" >> Xmodem >> Point to the .npk location.
It might take about an hour, but works. Had do do that in a couple of rb1100ahx2 that wouldn`t netinstall. Worked perfectly.
jarda
Mon Nov 24, 2014 6:37 pm
Read again the first post. Not all devices have serial port.
mrphreak
Mon Nov 24, 2014 9:15 pm
No, but the RB800 that pizzulicchio has, should.
NathanA
Forum Veteran
Forum Veteran
Tue Nov 25, 2014 12:34 pm
Are you absolutely sure about this? I could swear that "Firmware Upgrade" over serial is for RouterBOOT upgrades (FWF file) only. I don't think it can accept a system NPK to install to the NAND flash, but I confess I have never actually tried this. If it can, it is an undocumented feature (http://wiki.mikrotik.com/wiki/Manual:RouterBOOT), and I would honestly be shocked if this was possible.
-- Nathan
Cha0s
Forum Veteran
Forum Veteran
Mon May 30, 2016 10:08 pm
Please,
Users browsing this forum: Baidu [Spider], sindy and 89 guests
