Chupaka
v6.21 released!
Thu Oct 30, 2014 6:29 pm
What's new in 6.21 (2014-Oct-30 12:34):
*) userman - fix "Your session has been reset due to inactivity" error;
*) timezone - updated timezone information to 2014i release;
*) wireless - fixed scanning tool crash for 802.11ac interfaces
*) wireless - fixed Nv2 kernel panic on 802.11ac interfaces
*) quickset - added vpn configuration to Wifi AP %26 Ethernet modes as well;
*) lte - changed device identification for devices which regenerate MAC address,
most likely this will loose device's configuration;
*) sstp - fixed disconnects on high traffic load;
*) ovpn client - fixed problem where ip address was not added to bridge interface in ethernet mode;
*) webfig - show properly Switch Port configuration;
*) disks - fixed support for MMC/SD cards;
*) winbox - added filtering by dscp to torch;
*) certificate - fix CRL handling in trust chain;
*) fixed 6to4 tunnels having inactive routes;
*) ipsec - fix downgrade problem to v5;
*) ipsec - disallow template-policy-group=none in peer config and set it to 'default';
*) metarouter - some metaroutes didn't have their licenses;
*) torch - possibility to filter by dscp;
*) fixed - master port on AR8327 switches that is put into bridge could sometimes not work properly;
*) fixed queues - could have huge latencies and smaller throughput than specified;
*) interfaces report last link up/down time and link down count;
If you already run some RouterOS v6.x version, simply click “Check for updates” in QuickSet, Webfig or Winbox packages menu.
Others: http://www.mikrotik.com/download
Chupaka
Re: v6.21 released!
Thu Oct 30, 2014 6:34 pm
guys, please comment on this change. what queues? in what conditions?
honzam
Re: v6.21 released!
Thu Oct 30, 2014 9:26 pm
Any info about it? I can´t find it on SXT r2
Chupaka
Re: v6.21 released!
Thu Oct 30, 2014 10:17 pm
/interface print detail
<bla-bla-bla>
 4  R  name="vlan1321" type="vlan" mtu=1500 actual-mtu=1500
       mac-address=00:00:00:00:00:01 fast-path=no
       last-link-up-time=oct/30/2014 20:16:15 link-downs=0
Chupaka
Re: v6.21 released!
Thu Oct 30, 2014 10:18 pm
by the way, not fixed for me :) "gateway=6to4tunnel" still doesn't work, route is not active
normis
RouterOS v6.21
Fri Oct 31, 2014 10:16 am
Simply click “Check for updates” in QuickSet, Webfig or Winbox packages menu.
honzam
Re: RouterOS v6.21
Fri Oct 31, 2014 10:30 am
Only in terminal?
Modestas
Re: v6.21 released!
Fri Oct 31, 2014 10:47 am
Hi
Take care.
I've just upgraded my 450G to 6.21. Now box reboots right after starting services, gives not enough time to even enter password in CLI.
BR
Modestas
normis
Re: v6.21 released!
Fri Oct 31, 2014 10:55 am
Hi
Take care.
BR
Modestas
Please connect a serial cable and check what is written on the output before it reboots. Once you have copied this and emailed support, you can Netinstall the device with v6.21 to fix the reboot
Chupaka
Re: RouterOS v6.21
Fri Oct 31, 2014 10:58 am
Normis, please comment on this change... we need more details :)
Modestas
Re: v6.21 released!
Fri Oct 31, 2014 11:12 am
Hi
Take care.
BR
Modestas
Hi
There are no specific messages before reboot (see CLI output below). Device just issues double beep and restarts
RouterBOOT booter 3.18
RouterBoard 450G
CPU frequency: 680 MHz
Memory size: 256 MiB
NAND size: 512 MiB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
Starting...
RouterBoard 450G
NAND size: 512 MiB
Starting...
Starting services...
MikroTik Login: admin
Password:
RouterBoard 450G
Thank you for suggestion to try netinstall.
BR
Modestas
CyberTod
Long time Member
Long time Member
Re: v6.21 released!
Fri Oct 31, 2014 11:21 am
Excellent addition. But it is visible only in terminal and the time shown does not account for timezone.\
nz_monkey
Re: v6.21 released!
Fri Oct 31, 2014 11:33 am
A huge Thank You to Mikrotik! This feature is very useful.
This is currently CLI only via "/interface print detail" and works for all interface types.
It will be in WinBox from 6.22
gnuttisch
Re: RouterOS v6.21
Fri Oct 31, 2014 12:30 pm
I have updated a RB493 and a RB951G-2HnD and went well.
I have some ptp-links whit NV2 still running on 5.26. Is their any ideas to upgrade them to 6.21 also? or are the wireless changes in 6.xx only for the bugs that have been released in 6.xx =)
normis
Re: RouterOS v6.21
Fri Oct 31, 2014 1:41 pm
modestas
please let us know if netinstall helped. also, what configuration did you have there? which version did you upgrade from?
noyo
Re: RouterOS v6.21
Fri Oct 31, 2014 1:50 pm
after upgrading v5.26 --> v.6.21 :(
http://kazuko.pl/pryw/31102014185.mp4
thanks mikrotik
PastuhMedvedey
Re: RouterOS v6.21
Fri Oct 31, 2014 2:08 pm
After updating the device RB SXT G-2Hnd with 5.20 to 6.21, the device stopped working. Rebooting does not help.
bommi
Re: RouterOS v6.21
Fri Oct 31, 2014 2:16 pm
There is also an firmware update for my 951G-2HnD to version 3.19.
Any news what has changed?
This site has not yet been updated:
http://wiki.mikrotik.com/wiki/RouterBOOT_changelog
cmoegele
Re: RouterOS v6.21
Fri Oct 31, 2014 2:39 pm
m8 is this senseful? Are you upgrading XP directly to Win8.1 ?
Even an upgrade from 5.26 ( with new firmware) could have some risks, ....
With netflash you will get your device back to work.
normis
Re: RouterOS v6.21
Fri Oct 31, 2014 2:49 pm
Until further notice, please refrain from upgrading if you are running v5.x
We have found something and are investigating. Upgrades from v6.x seem to be working fine though
PastuhMedvedey
Re: RouterOS v6.21
Fri Oct 31, 2014 2:53 pm
Thank you. Netinstall restore operation.
PastuhMedvedey
Re: RouterOS v6.21
Fri Oct 31, 2014 2:57 pm
Upgrading from 6.x to 6.21, without problems. Thank you.
napismizpravu
Re: RouterOS v6.21
Fri Oct 31, 2014 3:08 pm
RB433UAH
upgrade 6.2x >6.22rc3
again error USB Flash disk problem + proxy
http://forum.mikrotik.com/viewtopic.php ... 78#p454175
apteixeira
Trainer
Trainer
Re: RouterOS v6.21
Fri Oct 31, 2014 3:20 pm
CRL error persists: "OpenVPN Server error: TLS failed".
Previous post: http://forum.mikrotik.com/viewtopic.php?f=2&t=88372
I tested with several certificates: issued by GoDaddy, CACert and using OpenSSL. If you create then without CRL the connection established correctly.
Here are some images:
Best regads.
Chupaka
Re: RouterOS v6.21
Fri Oct 31, 2014 3:50 pm
I saw someone already wrote something like this, but without red color :)
WARNING!
do NOT use "/system ntp client set servers-dns-names=" together with static DNS servers - your router won't boot next time, you will need to reset configuration
tested on our production CCR...
normis
Re: RouterOS v6.21
Fri Oct 31, 2014 4:01 pm
We have removed v6.21 from the webpage until the upgrade issue is fixed. It is caused by different disk management in new v6.21
Users browsing this forum: Ahrefs [Bot], Google [Bot], Semrush [Bot] and 34 guests
