evince
Process logging 100% CPU
Mon Nov 03, 2014 12:50 pm
Hi all,
I have a problem with 1 one my units. It is a RB2011UAS-RM running 6.20.
The CPU load is 100% and i can see the logging proccess using the whole cpu.
How can i stop it without rebooting the router? It is in production so i can not reboot it.
Thank you in advance.
Caci99
Re: Process logging 100% CPU
Mon Nov 03, 2014 1:31 pm
Go to /system logging and try disabling one by one the log rules until the CPU drops. Than analyze the one causing it.
-Toni-
Don't crash the ambulance, whatever you do
evince
Mon Nov 03, 2014 1:33 pm
Thank you for your help.
I can not do this because i have a blank window when i display the logging settings, nothing appears :(
Caci99
Mon Nov 03, 2014 1:43 pm
even if you try for terminal? terminal might be a bit lighter than winbox, so it might be easier for the CPU to display the rules.
-Toni-
evince
Mon Nov 03, 2014 10:20 pm
Yes, i get a timeout every command i write depending logging.
lambert
Long time Member
Long time Member
Tue Nov 04, 2014 2:01 am
Can you get it to export the configuration via telnet or SSH connection? It may not export the entire config you may want to only '/ip firewall export'
If you can, are there any firewall rules which log packets? If so, try to disable the rule. If not just disable all entries under /system logging.
/system logging disable [find]
Users browsing this forum: No registered users and 95 guests
