keema
NAT Masquerade problem in 6.20.1
Thu Nov 06, 2014 12:59 pm
Here is the situation; I have an eoip tunnel from main router to a remote router somewhere else in the building. Over this tunnel I have established a pppoe link. It all works up to a point, where I need to set a NAT masquerade rule for pppoe tunnel. Before 6.20.1 I could do this without a problem, with 6.20.1 it gives me error: --- in/out interface matcher not possible when interface [pppoe-xxx-xxx] is slave - use master instead [eoip-xxx-xxx].
The rule is RED as invalid.
Any clues?
jacekes
Re: NAT Masquerade problem in 6.20.1
Thu Nov 06, 2014 3:37 pm
Show the configs of the interfaces on both sides and the NAT rule. A schematic, including IP addressing, would be very helpful. It's difficult to help you, when you don't even say what you want to NAT.
I was certified a long time ago:
MTCNA# 1210NA193 MTCTCE# 1210TCE056 MTCWE# 1211WE010
ONE NETWORK DIAGRAM IS WORTH MORE THAN A THOUSAND WORDS!
keema
Thu Nov 06, 2014 4:09 pm
The eoip and pppoe links are working as expected, the problem is only in NAT rule, so you shouldn't need any other config then what I pasted below:
 0    chain=srcnat action=masquerade out-interface=pppoe-adsl log=no
      log-prefix=""
Thank you for trying to help.
jgellis
Sun Dec 28, 2014 2:09 am
I just upgraded and also ran into the same error. Perhaps my resolution will assist you in finding yours.
In my case, I have an EoIP tunnel (running over VPN) from an external MT that was *Bridged* locally to an ethernet port. I was doing NAT and firewall filtering on traffic arriving from or departing to the remote network, so the rules were pointing to an in-interface or out-interface of the EoIP interface directly. After the ROS upgrade I had to change the rules to alleviate the error you have indicated, eliminating the in-interface or out-interface value, and instead using the in-bridge-port or out-bridge-port variable to point to my same EoIP interface. Note, this also requires enabling the use of IP firewall in Bridge settings.
- If I helped you solve your problem... I am now able to accept tax-deductible Karma donations!
keema
Tue Jan 06, 2015 12:35 pm
Thank you for your answer. in my case a reboot helped...
Users browsing this forum: Baidu [Spider], Google [Bot] and 199 guests
