For example specify such info: "package-path: /nova"Please can someone tell how to configure the "package-path" and how the upload of a packag take place
[uldis@CAPsMAN] /file> print
# NAME TYPE SIZE CREATION-TIME
0 nova directory nov/05/2014 12:17:47
1 nova/wireless-cm2-6... package 884.1KiB nov/05/2014 12:17:43
2 nova/routeros-mipsb... package 9.7MiB nov/05/2014 12:17:48
You will see such entrie in the log file when the client connects/roams to some other CAP:Very interesting, could someone share info about how this "improved logging entries when client roams between the CAPs"
works? (ex. ping losses).
Peter
So, now there are 3 wireless packages:
wireless,
wireless-fp,
wireless-cm2.
What will happen with the wireless-fp package? Will it be discontinued?
CAPsMAN v2 is not capwap compliant due to limitations of capwap protocol.Why cannot v1 CAPs connect to v2 CAPsMAN or vice-versa? Aren't CAPsMAN v1 and v2 both RFC5416 (CAPWAP) compliant?
-- Nathan
But then, if CAPsMAN v1 was, shouldn't you perhaps call this one something different? Like "MTCAPsMAN" for example.CAPsMAN v2 is not capwap compliant due to limitations of capwap protocol.Why cannot v1 CAPs connect to v2 CAPsMAN or vice-versa? Aren't CAPsMAN v1 and v2 both RFC5416 (CAPWAP) compliant?
-- Nathan
we are not aware of such bug Could you tell us more detailed what exactly stopped working with the provision rules?I have a recommendation for the next release - check provisioning configuration for corrupt or invalid settings and advise user when upgrading. I had to remove and add a provisioning rule which became corrupt, but it looked normal from the cli and winbox.
If not for upgrade, maybe a button to check for any settings marked as invalid or e.g. Rule with interface configured that does not exist any more. Important to check even the disabled settings and the entire device.
Most likely the lowest channel is the least used in that area.For some reason, based on 6.22rc7 and 6.22final both the provisioning feature did not provision random channels, it only provision the lowest channel available of the country-settings.
in registration table you can already see the rx and tx statistics for each mac address.Is this feature requested available now http://forum.mikrotik.com/viewtopic.php?f=7&t=85974
Sorry didnt check. Hopefully we will get CCQ soon?in registration table you can already see the rx and tx statistics for each mac address.Is this feature requested available now http://forum.mikrotik.com/viewtopic.php?f=7&t=85974
From my testing on v2 all AP's end up on channel1Is auto channel support on this V2?
Did you enable CAP on a wireless interface?I have a 951G-2HnD and a cAP2n both running 6.22.
I downloaded wireless-cm2-6.22-misbe.npk and pushed it to both devices.
The 951G happily installed the package.
The cAP2n ignores it.
What did I miss?
j
Hello, I have looked further into this, and it looks like the cause of the problem was a backup file for a different model being restored to this device, which corrupted lots of settings and filled the storage with many random folders in web-proxy causing 100% cpu. Upon resetting to the correct backup file, all is OK. Typical user error!we are not aware of such bug Could you tell us more detailed what exactly stopped working with the provision rules?I have a recommendation for the next release - check provisioning configuration for corrupt or invalid settings and advise user when upgrading. I had to remove and add a provisioning rule which became corrupt, but it looked normal from the cli and winbox.
Yes, everything was already set up and working with CAPsMAN1. The problem is that I cannot get the cAP2n to install the package. Pushed the file to both devices, rebooted both. 951G has the new package installed after reboot and has removed the file, the cAP2n has NOT installed the package and the file remains.Did you enable CAP on a wireless interface?I have a 951G-2HnD and a cAP2n both running 6.22.
What did I miss?
j
CAPsMAN is mostly meant for managing of access points in hotels, homes, apartments, offices etc. the clients in these places are windows and mac laptops, phones etc.Are there any plans for Nv2 support in CAPsMAN?
Specify width 20 and then specify the extension-chaneel option to get the 20/40mhz option.i'm not be able to set the extension channel using CAPsMan v2.
I can only set the channel using 20Mhz.
If i set 40 mhz stops working with the error
"unsupported channel"
What is wrong?
is it a know issue?
It would appear the auto channel feature is broken in v2,
I have tested it in a clean environment with 10+ AP's all on channel 1 and used CAPsMANv2 to deploy 3 AP's and they all loaded using Channel 1.
If you look at the current stat of the CAP while you disable and enable it flicks to selecting-channel for a ms and always loads channel 1
Can anyone else confirm the auto-channel is broken in v2?
I have just loaded the latest version 6.23rc2 and get the same results, but the version control in CAPsMANv2 works well![]()
Steve
redbullsteve, please upgrade the RouterOS to v6.23rc8 where the Auto frequency option is working for CAPsMAN v2.
Please upgrade the CAPsMAN v2 to RouterOS v6.23rc10 and check again.Hi,
after upgrade to 6.22 and CAPsMAN v2 I have problem with virtual APs, I am not able to connect to them. When I moved vAP cfg to primary AP on the same HW, it works immediately - so it should be ok from cfg perspective. RB922UAGS-5HPacD+R11e-2HPnD and RB951G-2HnD, CAPsMAN running on different HW. All 6.22.
Anybody else with the same behaviour?
Thx.
Local forwarding.Please upgrade the CAPsMAN v2 to RouterOS v6.23rc10 and check again.Hi,
Thx.
You use local or full forwarding?
This is clear, question was related to version upgrade of cm2 package. I.e. which of them is important in this case? Both?you need to upgrade both CAPsMAN and CAP boards to wireless-cm2 package.
I thing, you need more work about fast roaming in capsman 2CAPsMAN is mostly meant for managing of access points in hotels, homes, apartments, offices etc. the clients in these places are windows and mac laptops, phones etc.
/caps-man access-list
add action=accept client-to-client-forwarding=yes interface=all signal-range=-80..120
add action=reject interface=all signal-range=-120..-81
:local MAXsignal "-78";
:local capsClientId;
:local capsClient;
:local capsClientSignal;
:foreach i in=[/caps-man registration-table find] do={
:set capsClientId [/caps-man registration-table get $i];
:set capsClient [/caps-man registration-table get $i mac-address];
:set capsClientSignal [/caps-man registration-table get $i rx-signal];
:if ("$MAXsignal" > $capsClientSignal) do={
/caps-man registration-table remove $i;
:log info "Caps script kick user $capsClient signal $capsClientSignal";
Warning: If there is no entry in ACL about client which connects to AP (wireless,debug wlan2: A0:0B:BA:D7:4D:B2 not in local ACL, by default accept), then ACL for this client is ignored during all connection time.
For example, if client's signal during connection is -41 and we have ACL rule
/interface wireless access-list
add authentication=no forwarding=no interface=wlan2 signal-range=..-55
Then connection is not matched to any ACL rule and if signal drops to -70..-80, client will not be disconnected.
To make it work correctly it is required that client is matched by any of ACL rules.
If we modify ACL rules in previous example to:
add interface=wlan2 signal-range=-55
add authentication=no forwarding=no interface=wlan2 signal-range=..-56
Then if signal drops to -56, client will be disconnected.
hi ebreyit
no way, i test it on 6.23 capsman v2 9-12-2014 , and access list works only when you connecting ..
and faster testet on capsman 1 on 6.22,6.23-rc
add access list
add action=reject interface=all signal-range=-120..-70
connect with good signal 120..-60 and then go away then signal go to -76 and worses
bleblas
re
i have access rule but it was secend, i change to first accept and then reject and check.
thx
bleblas
nuruhadyatef.
TP-Link can only work as a normal CPE in a Mikrotik CAPsMAN configured network.
The AP (CAPs) you can use for Mikrotik WLAN controller (CAPsMAN) has to be a RouterOS powered AP, but you will want to use Mikrotik AP for compatibility reasons.
The space you want to cover will usually determine the type of AP you want to use.
For the WLAN controller (CAPsMAN), almost any Mikrotik router can be used as the WLAN controller, but you need to consider the CPU and memory of the router because that will determine the numbers of AP (CAPs). CPE, user and traffic that the WLAN controller will be able to handle.
Another thing to note is all Mikrotik device must have a post 6.14 RouterOS but you will want to go for the latest RouterOS, there has been a lot of improvement and bug fixes after 6.15. Remember also that CAPsMAN V1 is not compatible to CAPsMAN V2.
Hope this help
Like I said before, a lot of things will determine what type of AP you want to use. About all Mikrotik AP will do, as long as it has the right RouterOS version.nuruhadyatef.
Hope this help
thx for yr repky
you put ne in the right way
can you give a recommendation of MT AP types you suggest
This is a feature that I think needs to be added, I have the same problem, I raised it a while ago but Mikrotik don't seem to understand the requirement and think the way it is currently implemented is the way forward.Hi,
Currently getting to grips with CAPsMAN2.
I've been experimenting with channel allocation and setting them to "auto" / blank.
At the moment the auto frequency option selects any channel (1 to 11) and this can lead to AP channel overlap (using 20 MHz channels). It appears as though as long as there is no overlap/interference with the 5 MHz centralish channel it will allocate the next one along.
Therefore in the 2GHz frequency range I only want the auto frequency to select from channels 1, 6 and 11.
From memory I need to create a scan-list that includes 2412, 2437, 2462. I expect this to prevent the overlap problem - to an extent.
However in CAPsMAN2 I don't seem to be able to choose scan list is an option?
Is this not a feature? Perhaps I'm looking at it from the wrong angle?
Can anyone help?
Regards
Aidan
That's great...what platform were they using for the CAPsMAN?we have seen customers that manage more then 600 cap interfaces on one CAPsMAN.
Did you manage to narrow down cause of your problem? We're about to roll out 912's for our radio on a 1100AHx2 capsmanHaving a serious issue with capsman v2. radios are rb912's running the current version 6.25(started with the first beta of v2). we have carts of hp stream 11 with realtek wireless cards, when more than ~10-15 connect to a single access point the throughput drops to almost nothing and the client begin to drop off. this happens without transferring data just connected. when i disable capsman and run the ap unmanaged the issue mostly goes away. the client chipset is rtl8723be, i know your going to say its the realtek but this does not happen on my meraki ap's(trying to get away from meraki)
The capsman controller is a ccr1009 and caps devices are running in local forwarding mode. it appears that the capsman is having an issue with the keeping up with the clients.
I have removed capsman name and certificate common name and enabled caps,debug and wireless,debug. CAP discovery finds CAPsMAN, but after CAP Discover > Select, it says it did not find a suitable CAPsMAN (see screenshot)SubOrbit,
try to remote the CAPsMAN Name and Certificate common name and then check again if it establishes connection.
Also enable the caps,debug and wireless,debug logging so you would see the results of the CAPsMAN selection and some other debug logs.
Hmm, i thought i know the problem. But its not. it dont workif your cap interface in the full forwarding mode is in the bridge port with your local network then you will be in the same local network where you wireless clients are connected.
+1 for Last-IP2) In registration all information should be visible like in normal mode (last-ip, routeros version etc.)
I'm not sure but i think is the same for CAPSMAN. At the end you have one ap and is remotelly controlled.I plan to by a RB911G-2HPnD and a RB911G-5HPnD for AP. But they have Licence Level 3 : no Wireless AP permitted
But what about in CAPsMAN configuration?
I mean:
- one Licence Level 4/5/6 RB as CAPsMAN,
and
- RB911G-2HPnD/-5HPnD serie as CAP device.
Uldis said: "you need RouterOS Level 4 licenese to make a board as a CAP AP.I'm not sure but i think is the same for CAPSMAN. At the end you have one ap and is remotelly controlled.I plan to by a RB911G-2HPnD and a RB911G-5HPnD for AP. But they have Licence Level 3 : no Wireless AP permitted
I mean:
and
I think you need L4 license to have more tan one client in local or CAP (ptp link is allowed with L3 license).
I've buyed 2 SXT Lite2 and are L3. They say: "SXT Lite2 is a low cost, high transmit power 2.4GHz (2312 -2732MHz depending on country regulations) outdoor wireless device. It can be used for point to point links or as a CPE for point to multipoint installations"
Anyway not tried yet but i've readed ptp is posible with L3 and bridge/station bridge mode.
I'm not 100% sure. Only logic answer.
Ok. I understand you now but, this is an option for a inadvisable full bridged network. Broadcast domain becomes huge and have their pants down for a broadcast storm. Best route at CPE and isolate your network from client's broadcast. Ap mode under CAPsMAN would be advisable. I'm right?Currently CAPsMAN is not designed for management of the WISP APs as it doesn't support Bridge mode that is required for Station-Bridge and WDS that is required for the Station-WDS.
We might add those features later when we have finished the rest of the CAPsMAN planned features.
Hello, Is there a list available with the (roadmap) new features?Currently CAPsMAN is not designed for management of the WISP APs as it doesn't support Bridge mode that is required for Station-Bridge and WDS that is required for the Station-WDS.
No, this is not correct. When he gets a connection with CAPsMAN again, he will send the WiFi signal again.I'm just starting to demo the CAPsMANv2.
When I remove the CAPsMAN from the network for a few seconds and reconnect my APs(CAPS) do not reconnect unless I reboot or disable/re-enable the CAP in the wireless interface of the AP.
Is this normal? Is there a setting I'm missing that allows the units to sync back together after a brief interruption?
I appreciate any feed back.
could you tell more about your infrastructure and mikrotik OS / Capsman version?I appreciate the quick response.
My problem is I unhooked the CAPsMAN controller from the LAN for about 30 seconds and plugged it back up. Once plugged back in the access points never sync back with the controller? You'd think this would happen quickly and automatically. But, I'm unable to get the units to SYNC back with the controller unless I reboot or disable/re-enable the CAP on the AP.
Worst case scenario. My controller drops offline for 5 minutes. Would I be required to go around and reboot 200 APs to regain sync to the controller? Do I need to implement a script to disable/re-enable the CAP. How do other people get their equipment to regain access to the controller?
Thanks!
Hmm, could you upload a image of your settings for CAPsman?I'm working in a testing environment with a very basic layout.
I'm using the latest version of Router OS and CAPsMANv2 on 6.27.
I have a 5 port RB450G gateway connected to a 5 port 750UP POE switch powering 4 RB912UAG-2HPnD APs. I have the 450G acting as the controller for the 4 APs.
Everything works fine until the AP loses connection to the controller for as little as a few seconds. After that the AP never re-establishes a connection back to the controller.
Thanks!
Using wireless-cm2 package and connected via MAC.are you using wireless-fp package or wireless-cm2 package?
The CAPs are connected to CAPsMAN via MAC connection or IP connection?
could you try it with IP addresses? I work with IP's and it works fine.Using wireless-cm2 package and connected via MAC.are you using wireless-fp package or wireless-cm2 package?
Very basic created Config and applied to the CAP when it showed up in the interfaces.
Again, everything works fine until the CAP disconnects from the controller. There after it will not reconnect until the CAP is disabled/re-enabled or the AP is power cycled.
Thanks!
I tested for a bit longer. I originally tested with only the CAPsMAN Address (IP) configured in the CAP. Once I added the CAPsMAN Name everything started syncing immediately after reconnecting to the network.could you try it with IP addresses? I work with IP's and it works fine.Using wireless-cm2 package and connected via MAC.are you using wireless-fp package or wireless-cm2 package?
Thanks!
one solution is manipulating datarates, disabling slower datarates client jump to another AP before reaching such lower signal level.I thing, you need more work about fast roaming in capsman 2CAPsMAN is mostly meant for managing of access points in hotels, homes, apartments, offices etc. the clients in these places are windows and mac laptops, phones etc.
Wifi device need to lost of signal on cap1 to connect another cap2, but wifi device can work long time with cap1 on signal -89 even the cap2 is closer with signal -40
bleblas
i note the same result using acl to disconnect weak signal clients, i think client signal strength fluctuate a lot and generates false positives on the acl.All units are now running on 6.25 and I'm still seeing a lot of disconnects and moving between APs. Sample of the logs are below. All these devices are stationary in the building...
08:22:03 caps,info 74:E2:F5:22:12:67@AP2-Net1 connected
08:22:03 caps,info 74:E2:F5:22:12:67@AP1-Net1 disconnected, registered to other interface
08:22:07 caps,info 9C:04:EB:31:9B:BF@AP1-5GHz-Net2 connected
08:22:19 caps,info 9C:04:EB:31:9B:BF@AP1-5GHz-Net2 disconnected, too weak signal
08:23:23 caps,info F4:1B:A1:9A:19:0A@AP1-Net1 connected
08:23:29 caps,info F4:1B:A1:9A:19:0A@AP1-Net1 disconnected, 4-way handshake timeout
08:23:30 caps,info C8:85:50:6C:11:0B@AP1-Public-5G connected
08:23:30 caps,info C8:85:50:6C:11:0B@AP2-2.4GHz-Public disconnected, registered to other interface
08:23:31 caps,info C8:85:50:6C:11:0B@AP1-2.4GHz-Public connected
08:23:31 caps,info C8:85:50:6C:11:0B@AP1-Public-5G disconnected, registered to other interface
08:23:37 caps,info 80:E6:50:11:A2:26@AP1-5GHz-Net2 connected
08:23:40 caps,info B8:E8:56:76:05:C3@AP2-5GHz-Net2 connected
08:23:40 caps,info B8:E8:56:76:05:C3@AP1-5GHz-Net2 disconnected, registered to other interface
08:23:43 caps,info 80:E6:50:11:A2:26@AP1-5GHz-Net2 disconnected, too weak signal
08:23:46 caps,info B8:E8:56:76:05:C3@AP2-5GHz-Net2 disconnected, too weak signal
08:23:48 caps,info B8:E8:56:76:05:C3@AP1-5GHz-Net2 connected
08:23:50 caps,info 80:E6:50:11:A2:26@AP1-5GHz-Net2 connected
08:23:54 caps,info C8:85:50:6C:11:0B@AP1-2.4GHz-Public disconnected, extensive data loss
08:23:56 caps,info 80:E6:50:11:A2:26@AP1-5GHz-Net2 disconnected, too weak signal
08:24:05 caps,info 80:E6:50:11:A2:26@AP1-5GHz-Net2 connected
08:24:08 caps,info 80:E6:50:11:A2:26@AP1-5GHz-Net2 disconnected, too weak signal
Please contact support@mikrotik.com about this problem and also tell us how you are measuring the performance.testing package on rb951g
without connecting to CAPSMAN
slower wifi performance and random disconnects
ros 6.27, firmware 3.22
rolling back to wireless-fp
17:38:57 caps,info 84:63:D6:98:85:0C@cap3 disconnected, extensive data loss
17:38:58 caps,info 00:BB:3A:F6:70:02@cap6 disconnected, 4-way handshake timeout
17:39:06 caps,info 00:BB:3A:F6:70:02@cap6 connected
17:39:12 caps,info 00:BB:3A:F6:70:02@cap6 disconnected, 4-way handshake timeout
17:39:12 caps,info 00:BB:3A:F6:70:02@cap2 connected
17:39:16 caps,info 00:BB:3A:F6:70:02@cap2 disconnected, received disassoc: sending station leaving (8)
17:39:20 caps,info 00:BB:3A:F6:70:02@cap6 connected
17:39:26 caps,info 00:BB:3A:F6:70:02@cap6 disconnected, 4-way handshake timeout
17:39:26 caps,info 00:BB:3A:F6:70:02@cap2 connected
17:39:30 caps,info 00:BB:3A:F6:70:02@cap2 disconnected, received disassoc: sending station leaving (8)
17:39:34 caps,info 00:EE:BD:AB:4D:93@cap5 connected
17:39:35 caps,info 00:EE:BD:AB:4D:93@cap3 disconnected, registered to other interface
17:39:35 caps,info 00:BB:3A:F6:70:02@cap6 connected
17:39:41 caps,info 00:BB:3A:F6:70:02@cap6 disconnected, 4-way handshake timeout
17:39:41 caps,info 00:BB:3A:F6:70:02@cap2 connected
17:39:47 caps,info 00:BB:3A:F6:70:02@cap2 disconnected, 4-way handshake timeout
17:40:03 caps,info CC:89:FD:A8:90:CC@cap6 connected
17:40:09 caps,info CC:89:FD:A8:90:CC@cap6 disconnected, received disassoc: unspecified (1)
17:40:13 caps,info CC:89:FD:A8:90:CC@cap5 connected
17:40:18 caps,info CC:89:FD:A8:90:CC@cap5 disconnected, received disassoc: unspecified (1)
17:42:09 caps,info CC:89:FD:A8:90:CC@cap6 connected
17:42:14 caps,info CC:89:FD:A8:90:CC@cap6 disconnected, received disassoc: unspecified (1)
17:42:19 caps,info CC:89:FD:A8:90:CC@cap5 connected
17:42:23 caps,info E8:99:C4:B7:15:5E@cap2 disconnected, received disassoc: sending station leaving (8)
17:42:24 caps,info CC:89:FD:A8:90:CC@cap5 disconnected, received disassoc: unspecified (1)
17:44:15 caps,info CC:89:FD:A8:90:CC@cap6 connected
17:44:20 caps,info CC:89:FD:A8:90:CC@cap6 disconnected, received disassoc: unspecified (1)
17:44:25 caps,info CC:89:FD:A8:90:CC@cap5 connected
17:44:30 caps,info CC:89:FD:A8:90:CC@cap5 disconnected, received disassoc: unspecified (1)
Any news about :
- live auto frequency selection per AP ( based on live Spectrum , without having enable/disable interface )
- auto Tx-power control ( based on own neighbour Ap's )
or is this already build in at the moment ?
ok lets take other brands marketing to the reality:Any news about :
maybe better id is to let the Ap create its own little statistics database in some time about freq / neighbours / CCQ etc. and let the Ap make a decision of what settings to use based on statistical information over some time.o do that you request its necessary a second radio on the ap for the only purpose or spectrum analysis and neighbor monitoring.
Automatic spectrum analysis requires a development beyond the actual scope of ROS.
Some people like all in life to be automatic but it has associated costs.
i will be happy with datarates and ht mcs manageable from CAPsMAN its the only thing prevents me from using CAPsMAN
http://www.mikrotik.com/download/share/ ... mipsbe.npkHi!
Where can I get package of CAPsMan v2 for 6.29 (RC20)? in all_files is not there..
Thank you.
12:08:15 caps,info IPhone6_A@AP_Switchruimte connected
12:08:21 caps,info IPhone6_A@AP_Woonkamer_Pa_en_Ma connected
12:08:21 caps,info IPhone6_A@AP_Switchruimte disconnected, registered to other interface
12:13:05 caps,info Samsung_Tab@AP_Switchruimte connected
12:26:38 caps,info Laptop@AP_Switchruimte connected
12:26:38 caps,info Laptop@AP_Woonkamer_Pa_en_Ma disconnected, registered to other interface
12:32:10 caps,info Laptop@AP_Woonkamer_Pa_en_Ma connected
12:32:10 caps,info Laptop@AP_Switchruimte disconnected, registered to other interface
12:08:15 caps,info 8C:29:37:C1:02:1E@AP_Switchruimte connected
12:08:21 caps,info 8C:29:37:C1:02:1E@AP_Woonkamer_Pa_en_Ma connected
12:08:21 caps,info 8C:29:37:C1:02:1E@AP_Switchruimte disconnected, registered to other interface
12:13:05 caps,info D4:F4:6F:9B:EB:9A@AP_Switchruimte connected
12:26:38 caps,info 8C:29:37:C1:02:1E@AP_Switchruimte connected
12:26:38 caps,info 8C:29:37:C1:02:1E@AP_Woonkamer_Pa_en_Ma disconnected, registered to other interface
12:32:10 caps,info 8C:29:37:C1:02:1E@AP_Woonkamer_Pa_en_Ma connected
12:32:10 caps,info 8C:29:37:C1:02:1E@AP_Switchruimte disconnected, registered to other interface
Answered in post 13 of the first page of this thread:Why cannot v1 CAPs connect to v2 CAPsMAN or vice-versa? Aren't CAPsMAN v1 and v2 both RFC5416 (CAPWAP) compliant?
-- Nathan
MegaThanxIt shows GN because that only-n mode only changes the basic-rates setting, G mode data-rates are still used. Here is the table with the explanation for each mode:
http://wiki.mikrotik.com/wiki/Manual:In ... Rate_table
Starting from 6.30 it's included in main package.where do I find cm2 package for 6.30 6.30.1?
didn't find it on the download page.
Thanks, so i'm going to update.Starting from 6.30 it's included in main package.where do I find cm2 package for 6.30 6.30.1?
Was this issue resolved? I'm having exactly the same problem.I have constant problems with certificates when running CAPsMAN and CAP on the same router. Whenever I do a fresh configuration, issue new CA & certificates and join local CAP to CAPsMAN on the same router, things work fine. However, after reboot of the router, I am starting to get certificate errors. Apparently CAP is trying to locally install Certificates it gets from CAPsMAN, but fails to do so, since the certificates are already installed (well, it's the same router!). This process keeps repeating for about 2 days, until router runs ouf of memory and rebootsI have no problems with CAPs that connect from other routers.
I have set local CAP configuration to Certificate: none, but the issue remains.
Any idea?
When I take a look at the logs, I see a lot of MAC addresses for all connecting clients.
is it possible to enter a description for these addresses to identify them ?
something likeinstead ofCode: Select all12:08:15 caps,info IPhone6_A@AP_Switchruimte connected 12:08:21 caps,info IPhone6_A@AP_Woonkamer_Pa_en_Ma connected 12:08:21 caps,info IPhone6_A@AP_Switchruimte disconnected, registered to other interface 12:13:05 caps,info Samsung_Tab@AP_Switchruimte connected 12:26:38 caps,info Laptop@AP_Switchruimte connected 12:26:38 caps,info Laptop@AP_Woonkamer_Pa_en_Ma disconnected, registered to other interface 12:32:10 caps,info Laptop@AP_Woonkamer_Pa_en_Ma connected 12:32:10 caps,info Laptop@AP_Switchruimte disconnected, registered to other interface
Code: Select all12:08:15 caps,info 8C:29:37:C1:02:1E@AP_Switchruimte connected 12:08:21 caps,info 8C:29:37:C1:02:1E@AP_Woonkamer_Pa_en_Ma connected 12:08:21 caps,info 8C:29:37:C1:02:1E@AP_Switchruimte disconnected, registered to other interface 12:13:05 caps,info D4:F4:6F:9B:EB:9A@AP_Switchruimte connected 12:26:38 caps,info 8C:29:37:C1:02:1E@AP_Switchruimte connected 12:26:38 caps,info 8C:29:37:C1:02:1E@AP_Woonkamer_Pa_en_Ma disconnected, registered to other interface 12:32:10 caps,info 8C:29:37:C1:02:1E@AP_Woonkamer_Pa_en_Ma connected 12:32:10 caps,info 8C:29:37:C1:02:1E@AP_Switchruimte disconnected, registered to other interface
It seems that the problem is related to the CAP not being able to load the certificate that was created when it first registered with the CAPsMAN (on the same device). When I select the issued certificate in the dialog box to enable CAP, the log shows "CAP connect to Router (xxxxx) failed: could not load certificate (6)"Was this issue resolved? I'm having exactly the same problem.I have constant problems with certificates when running CAPsMAN and CAP on the same router. Whenever I do a fresh configuration, issue new CA & certificates and join local CAP to CAPsMAN on the same router, things work fine. However, after reboot of the router, I am starting to get certificate errors. Apparently CAP is trying to locally install Certificates it gets from CAPsMAN, but fails to do so, since the certificates are already installed (well, it's the same router!). This process keeps repeating for about 2 days, until router runs ouf of memory and rebootsI have no problems with CAPs that connect from other routers.
Any idea?
I've the same problem with multiple installations running 6.30.2 - did you ever find a solution to this problem? For me it seems to be as the local CAP receives the certificate but the issued certificate does not show as PrivateKey available. (Screenshot shows a CRS109 with Capsman shows CA Cert with 4C5E0CA5654C MAC and Issued_3 shows CAP with MAC 4C5E0CA5654C but no private key available)I have constant problems with certificates when running CAPsMAN and CAP on the same router. Whenever I do a fresh configuration, issue new CA & certificates and join local CAP to CAPsMAN on the same router, things work fine. However, after reboot of the router, I am starting to get certificate errors. Apparently CAP is trying to locally install Certificates it gets from CAPsMAN, but fails to do so, since the certificates are already installed (well, it's the same router!). This process keeps repeating for about 2 days, until router runs ouf of memory and rebootsI have no problems with CAPs that connect from other routers.
Any idea?
I'm having the same problem. As soon as I reboot the CAP, it cannot use the generated certificate anymore but can also not generate a new one, because there is already a certificate for that hostname. The client on another router just connects fine.I've the same problem with multiple installations running 6.30.2 - did you ever find a solution to this problem? For me it seems to be as the local CAP receives the certificate but the issued certificate does not show as PrivateKey available. (Screenshot shows a CRS109 with Capsman shows CA Cert with 4C5E0CA5654C MAC and Issued_3 shows CAP with MAC 4C5E0CA5654C but no private key available)I have constant problems with certificates when running CAPsMAN and CAP on the same router. Whenever I do a fresh configuration, issue new CA & certificates and join local CAP to CAPsMAN on the same router, things work fine. However, after reboot of the router, I am starting to get certificate errors. Apparently CAP is trying to locally install Certificates it gets from CAPsMAN, but fails to do so, since the certificates are already installed (well, it's the same router!). This process keeps repeating for about 2 days, until router runs ouf of memory and rebootsI have no problems with CAPs that connect from other routers.
Any idea?
Screenshot of the certs of another CAP running on a different hardware shows correct behaviour - CAP Certificate with private key available:
I guess due to this behaviour restarting the CapsMan / CAP prevents the CAP to access the certificate, reissue is no option as it's not possible to issue a cert with the same common name (which seems to be a bug itself,...?)
somebody able to shed some light?
BG Christoph
It seems as if version 6.33rc16 solved the problem for me, at least for the first reboot. I will have an eye on it.Please upgrade to the RouterOS v6.33rcX and then check again after you request a new certificate.
Tommorow I separates capsman and firewal to different routerboard. I think problem is in max load core cpu. When I reduce firewall and queue rules The problem is less common.Hi profek412;
We are running CCR-1009 running V6.33rc16 with 935 interfaces and 307 caps connected.
This because we regularly loose all caps from the management only to return a few minutes after; while there are no interruptions measured between the caps and capsman (all caps are coming from different locations and we have capsmans in different datacentres with different uplinks)
We have a case open with MT as we try to reproduce the problem.
I start system on Monday, and I don's see 'disconnected, max key exchange retries' in log. We tested system on iphone and we don't have any problem.BTW: do you also regulary see the message : 'disconnected, max key exchange retries'?
We have this at regular basis and then the Apple devices lock and need to be turned wifi off/on again for everything to function properly again until this happens again.
Thank you for the report - we will try to fix it.We found a small bug in the latest (6.32.2) release. In webfig, when trying to copy a client to the access list (from the registrations tab in CAPsMAN v2) we get an internal server error and are redirected to the login screen. Doing the same thing with winbox works fine.
If you could provide us remote access to the CAPsMAN where this EAP test isn't working we could try to debug it.For us, we already have a split between FW and CAPSMAN function between separate hardware devices...
For the Max retries, check your apple macos logs for the following error message:
kernel[0]: inputEAPOLFrame: Received non-key EAPOL frame
Drives me nuts... EAP tests on other vendor equipment are working correctly
bleblas
Having the same issue, so sad. Using RB751 as a controller and grooves/caps as APs, ROS 6.34rc6. The controller takes 4 APs and have 50-100% CPU load and memory leakage. When 5th AP connects it just hangs up. I can't believe that controlling caps is so resource-intensive task. What am i supposed to do with that? Buy a CCR?We are massively deploying CAPSMANv2 now but are suffering controller cpu spikes to 100%.
Are we going to get WMM support in CAPsMAN any time soon?
What's new in 6.30 (2015-Jul-08 09:07):
*) wireless - added WMM power save suport for mobile devices;
This has no relation to CAPsMAN.Code: Select allWhat's new in 6.30 (2015-Jul-08 09:07): *) wireless - added WMM power save suport for mobile devices;
Yes, but how do you turn it on on CAPsMAN configuration? I had 3 stand-alone APs working fine when I enable WMM on their interfaces but yesterday I put them to work as CAPs and now I cannot enable WMM. Looking at Registration table on CAPsMAN I can see that devices are not staying registered more than 2-3 minutes (only when they are in use).Are we going to get WMM support in CAPsMAN any time soon?Code: Select allWhat's new in 6.30 (2015-Jul-08 09:07): *) wireless - added WMM power save suport for mobile devices;
You are right, sorry: This feature was enabled for capsman in 6.30 and revised in later firmwares because bugs.This has no relation to CAPsMAN.Code: Select allWhat's new in 6.30 (2015-Jul-08 09:07): *) wireless - added WMM power save suport for mobile devices;
What's new in 6.31 (2015-Aug-14 15:42):
*) wireless - improved WMM-PowerSave support in wireless-cm2 package
This is wireless client decision to disconnect from the AP. We don't have any control why they want to connect.- disconnected, received disassoc: sending station leaving (8)
I guess you missed something. I said everything was working fine before CAPsMAN. In the meantime I tried some of those devices on another AP without CAPsMAN and it is working without disconnect.We don't have any control why they want to connect.
Ok, now I am pretty sure there is some problem with CAPsMAN. I took one device (iPhone 6S with iOS 9.2) and connected it to CAP. It stays connected until it goes to sleep mode. Then I disabled CAP on that access point and configured it like stand alone AP. Then phone stays connected even when in sleep mode.This is wireless client decision to disconnect from the AP. We don't have any control why they want to connect.- disconnected, received disassoc: sending station leaving (8)
WMM PowerSave feature is always enabled in the CAPsMAN and can't be disabled.
Well, maybe not directly but if AP says to a client "No, I don't support WMM" and then client decided to disconnect because of that I would say it is one way of indirect control of client behaviour.We don't have any control why they want to connect.
Hi, I have the same issue, my capsman run on CCR-1036 v6.34.2 with 160 interface and 80 caps connected. Capsman regularly loose all caps from the management only and then return a few minutes after. This issue appear every about 4hours, after loose times my capsman auto reboot.Hi profek412;
Hello everyone!
I'm using CapsMan v2 on routeros 6.33.1 with several CAPs.
I noticed that the CapsMan registration table doesn't show "Last IP" info for connected stations. Caps don't seem to provide this information either. Is there a way, using CapsMan setup, to view "Last IP" info for connected stations?
When not using CapsMan, this info was available in the Registration table. But now it seems to be gone.
Thanks,
Kind regards!
Stoycho
