alim1369
50000 concuurent PPPOE session
Fri Nov 21, 2014 9:58 pm
hi all
i want to use Mikrotik as Central BRAS with high bandwidth throughput (more than 1Gbps).
now i decide to install OS on x86 server.
so what kind of server do you suggest regarding resources like RAM and CPU to support high BW.
I searched the forum and i found out that it is impossible with mikrotik, is it correct?
If so how can i have a central Mikrotik BRAS??? is there any way for integrate multiple system?
Regrads,
alim1369
Re: 50000 concuurent PPPOE session
Sat Nov 22, 2014 8:37 pm
No one can help?
sonny
Sun Nov 23, 2014 10:41 am
You can use 5-10 CCR´s and use them to load balance the sessions. It will work
Karl Sonnleitner
Senior Wireless-Expert
Restlesspowerbox - managed powersupply for Routerboards
rodolfo
Long time Member
Long time Member
Sun Nov 23, 2014 1:16 pm
sonny, how do you connect them?
I have all pppoe sessions trasnported in L2 using eoip.
rodolfo
IZ0UQV
bajodel
Long time Member
Long time Member
Fri Nov 28, 2014 9:47 am
how/where do you connect all such eoip?
alim1369
Sun Nov 30, 2014 9:19 pm
It means a CCR1009 can handle only 5000 pppoe session?
how can i load balancing pppoe server?
bajodel
Long time Member
Long time Member
Mon Dec 01, 2014 1:00 pm
in theory ..
https://aacable.wordpress.com/2011/09/0 ... -same-lan/
but in practice I do not know if it works well.
My question was instead how/where connect 50000 eoip tunnels
alim1369
Thu Dec 04, 2014 3:17 pm
in theory ..
No I have only 10 eoip tunnels and want to know can i have a centeral BRAS for 50000 pppoe connection?
thanks
markom
Thu Dec 04, 2014 4:48 pm
If you have 50k pppoe users then you are in serious business. Mikrotik is great but you need something like
Cisco 6400 fully loaded wit all 7 modules which will include 32k PPPoE clients.
http://www.cisco.com/c/en/us/support/do ... aq.html#q5
even then, you will need two of them.
If You are doing serious business then you need serious investments so be careful with choosing equipment's.
I am convinced that your investments will be paid off.
Because 6400 is end of life, you should use some router like Cisco ASR1002 10G which can support 64,000 tunnels.
If one pppoe client make only 1$ profit par month you can return your investment in less then one month, for price ~30.000$.
sonny
Mon Dec 08, 2014 10:34 am
@rodolfo
take a CCR 10XX and connect all EOIP tunnels theere.
Put them in a bridge then add more ethernet ports to that bridge.
On that ethernet ports you can connect BRAS systems, they will loadbalance for you automatically.
The faster one takes the pppoe session.
Karl Sonnleitner
rodolfo
Long time Member
Long time Member
Mon Dec 15, 2014 11:43 pm
tanks sonny :)
rodolfo
IZ0UQV
magnavox
Wed Nov 11, 2015 9:55 pm
That solution have you implemented? :)
Best Regards...
IPANetEngineer
Trainer
Trainer
Thu Nov 12, 2015 12:05 am
This might be helpful now that the CCR1072 is out.
http://www.stubarea51.net/2015/10/23/mi ... nd-queues/
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
Users browsing this forum: No registered users and 99 guests
