Hello Mikrotik Users,
I was wanting to know if there was any known ways to remove the QuickSet feature from winbox other than purchasing hardware that does not support it.
I have a 951-2n that I purchased for a friend, for this application I need the wireless interface to act as a station which receives DHCP from the network (like a CPE would, and then just the ethernet ports are used for LAN.)
Well QuickSet seems to require certain settings on Ether1 and every time I change my settings Quickset goes bananas and changes things back or just will not allow the config to work because quickset does not recognize that it has an IP that can route LAN traffic.
I was able to get my config to work via webfig after disabling QuickSet by removing it with the Design Skin function and saving it and the config works as expected, but I like Winbox much better and would prefer that when I login with Winbox it does not break the config.
While I do recognize that there might be a way to get the same effect without disabling QuickSet in winbox I don't know how to do it and it's not the first time I have had this headache with QuickSet and would prefer to just have the option to disable/remove it without downgrading RouterOS versions.
Any ideas? Does anyone know how to do this or do I need to make this into a feature request?
Best Regards,
Christopher
