MUM Europe 2020
Goasler
Can not Restore a Backup file
Fri Nov 28, 2014 8:27 am
i have made a Backup File from a Mikrotik RB1100
with Terminal "/System Backup". (no Password given)
Now we MUST Restore the Backup and the Router OS always say "Bad Passwort (6)"
Password Field disabled - Bad Passwort (6)
Password Field Activated but Empty Password - Bad Passwort (6)
what does mean the (6) behind "Bad Passwort"?
If i want restore on an older Firmware as 6.13
the Router OS say its not a valid Backup file or anything.
Is there any default Password given?
I have used the "Restore Password" Scripts from some Sites
where i have Uploaded the Backup File and it Says "No Passwords Found".
Can anyone or Mikrotik decrypt us the File?
Its very Important for ur Company!
huntah
Re: Can not Restore a Backup file
Fri Nov 28, 2014 10:31 am
Try using you login password if you haven't specified anything
Goasler
Fri Nov 28, 2014 10:37 am
I have tried ALL my passwords that i had used in my Life! But "Bad Passwort"
Give it a way how i can see the routeros Firmware version with i have made the Backup file?
hgonzale
Fri Nov 28, 2014 2:24 pm
If you leave an empty password, but you use encryption, the password is the encryption password (you password for admin access at moment of creating the backup).
you must use at least the same version for recover it.
boardman
Tue Aug 16, 2016 1:39 am
Hello
On "empty password" backup you need to use the password of the user who created the backup file. Hope this helps.
Regards
J. Boardman
jmmr84
Sat Oct 28, 2017 9:38 pm
Just in case some body need this. The solution is to execute this command on the terminal: /system backup load name="name of your backup file" password=no.
talhahome
Thu Dec 21, 2017 8:00 am
I tried to restore a backup old enough. So the user’s password has changed in the meantime. I used the previous password of that user to restore the backup. It worked for me.
garavi1983
Mon Feb 19, 2018 9:00 am
You must set password for ruterOS admin user it can't be blank.
TomKat
Sat Jan 18, 2020 12:49 am
As a side solution.
I just had the same issue where a backup file refused to load.
the error indicated an error with the password like the OP.
The end result was the router was out of space and unable to restore the file.
This was on 6.44 RB1100
Freeing up some space and the router did not display the error (6) and file was able to be restored.
(the original symptoms were the router would not boot and would seem to power cycle.
I did a reset to start it but the config was then wiped.)
Users browsing this forum: faxxe and 102 guests
