dpi
Using Radius for Accounting DHCP Server Entries without Auth
Sat Dec 13, 2014 10:30 pm
Is there a way to make the DHCP Server send Radius Accounting (START/STOP/interim-update) when the DHCP server assigns a new, updated, or expires a lease?
I tried some options on the Radius Web Menu but it seems like your required to have an Authentication port. I also don't see any activity when renewing a lease.
thanks,
Jayme
rizkcharbel
Re: Using Radius for Accounting DHCP Server Entries without Auth
Fri Feb 19, 2021 11:14 am
I have been trying to make this work but no luck, I think it is useless to enable radius accounting on DHCP level if you don't have the interim-update option, I believe that Mikrotik should solve this problem or just remove radius accounting from DHCP because its just confusing.
Users browsing this forum: Msosa, nickrod50, silencedugu and 156 guests
