echodhie
router bridge for traffic shapping
Fri Jun 23, 2006 3:35 pm
Help me ..
i want to shaping client with int bridge ..
CoreCisco ---ether1 ---- MT ---ether2 ---- Catalys
Can u help me please
maximan
Trainer
Trainer
Fri Jun 23, 2006 9:37 pm
You can do it.
but try to read this
http://linuxmafia.com/faq/Essays/smart-questions.html
Then explain that you want to do
Maximiliano
MKE Solutions > Professional Support IT (Spanish / English)
FastNetMon / FNM Manager: DDoS Detection Tools.
e2346437
Sat Jun 24, 2006 3:42 am
You can do it.
Maximiliano
I could not have said it better myself. Thanks Maximiliano!
Eric
Equis
Forum Veteran
Forum Veteran
Mon Jun 26, 2006 5:22 am
This kind man has example for you
http://forum.mikrotik.com/viewtopic.php?t=9278
jacknux
Tue Jun 27, 2006 10:18 am
Maybe this is not as simple as you think Maximan.
I have tried it too, but it's not working. This's the special case, that Mikrotik stands between cisco router & catalyst that act VLAN configuration. As you know, traffic in VLAN encapsulates by 802.1q protocol trunking.
Is Mikrotik smart enough to mark packet in this configuration?
Maybe there's on of Mikrotikest can help solved this problem?
***miko
savage
Tue Jun 27, 2006 11:53 am
Yes, it is.
Configure a VLAN1 and VLAN2 that is part of the VLAN on the network, and create a bridge on the VLAN interfaces instead of the Ether interfaces, and bobs your uncle, off you go?
Regards,
Chris
jacknux
Tue Jun 27, 2006 12:47 pm
I'm sorry savage, but I stiil don't understand what you mean. :)
Here I describe the scheme
Router (cisco) == mikrotik bridge == Switch (Catalyst)
Router & Switch communicates via VLAN protocol (802.1q)
Should I create VLAN interfaces on mikrotik? I try just just now, & my network is disconnect. :)
The purpose of this scheme is to create transparent bridging & shaping.
Any opinion?
janisk
Tue Jun 27, 2006 2:15 pm
Yes, it is.
here is your option, if you configure everything correclty you will succede
here is link to mikrotiks Virtual Private Networking
http://www.mikrotik.com/docs/ros/2.9/#V ... Networking
jacknux
Wed Jun 28, 2006 8:39 am
This's not a VPN exactly, just how to shape traffic in MT bridging beetwen router & catalyst that act as a VLAN configuration.
Like the scheme I have attached:
- bridging working properly
- mangle could trap the connection
but it couldn't enter the queue tree.
:-"..I think my configuration of traffic shaping is fine, based on documentaion & the forum.
thx
Users browsing this forum: afahmytik, Baidu [Spider], Bing [Bot], CyberDaeng, Google [Bot] and 131 guests
