zlatkomajstor
NTP Client not working in version 6.24
Fri Jan 02, 2015 12:25 pm
Upgraded my CCR1036 and RB1000 and NTP Client does not synchronize.
uldis
Re: NTP Client not working in version 6.24
Fri Jan 02, 2015 4:55 pm
You use built in ntp client or you have installed the additional NTP package?
ViREnG
Wed Jan 07, 2015 7:27 pm
Confirm . same problem on RB912 , ROS 6.24
I've Test all type of client (uni,many,multi,broadcast)
coylh
Thu Jan 08, 2015 5:09 am
Mine works (RB450G) though I'm using the ntp package.
suntelSean
Sat Jan 10, 2015 1:58 pm
Works on mine as well (at least in Unicast)
2011UiAS-2HnD Soho unit
I just set the SNTP servers to the IPs of the known NTP servers and voila, insta work.
zlatkomajstor
Tue Jan 20, 2015 4:47 pm
I installed all packages that are in version 6.24 including the ntp package.
hasanakgoz
Tue Jan 20, 2015 5:14 pm
Hi;
I have same problem. Cloud Core upgrade 6.25 but problem is continue. I send e-mail mikrotik support. waiting for mikrotik support .
marcodefreitas
Tue Feb 10, 2015 10:03 pm
I think it's a NTP server bug.
letabawireless
Fri May 01, 2015 12:56 am
Hi
Anybody got an answer on this ? I just upgraded to 6.28 on my CCR. NTP status just sits on "started".
suntelSean
Fri May 01, 2015 1:04 am
Export your NTP settings
Sent from my iPhone using Tapatalk
letabawireless
Sat May 02, 2015 1:23 pm
/system ntp client
set enabled=yes primary-ntp=196.25.1.1 secondary-ntp=196.25.1.3
Not a lot of things to set, this is why its so weird.
Users browsing this forum: BergDev and 134 guests
