infused
BGP issue?
Sun Jan 25, 2015 6:31 am
Hi Guys.
When running BGP, once my connection fails over, it never fails back. The behavior is quite weird. The main connection under bgp peers status says resent... then nothing. It stays in that state forever. The remote id, uptime etc are all black.
A reboot of the router fixes it, and it goes back to the main connection.
CCR on 6.19
lz1dsb
Re: BGP issue?
Sun Jan 25, 2015 12:35 pm
It is very likely that you have some misconfiguration either in your local system or on the remote BGP peer.
Could you post a configuration /bgp router export would do it...
Users browsing this forum: No registered users and 98 guests
