pakfar
Mikrotik & Windows Server 2008 Active Directory
Mon Jan 26, 2015 2:13 pm
Do MikroTik coordinated with Windows Server 2008 Active Directory?
Sync with AD
hossain2004a
Re: Mikrotik & Windows Server 2008 Active Directory
Mon Jan 26, 2015 4:32 pm
I think they don't relate to each other so there would be no problem with them, Imaging mikrotik is your Modem and compare it with Win server, there would be no problem?
P.S: I didn't test it yet, but will do in future
rmmccann
Mon Jan 26, 2015 9:50 pm
I think OP is referring to AAA using 2008 Active Directory.
I have been able to set up 802.1x authentication with my 2008 R2 Active Directory domain and Mikrotik wireless and radius. With a little further research I'm sure you could get AAA to handle router logins, hotspot, etc as well.
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. --Douglas Adams
DLNoah
Mon Jan 26, 2015 11:28 pm
Authentication for Winbox/Telnet router logins via Active Directory will not work, unless you store the password in AD with reversible encryption (WARNING: NOT RECOMMENDED). Winbox/Telnet AAA only supports PAP authentication, which requires a cleartext-password to authenticate.
scampbell
Trainer
Trainer
Tue Jan 27, 2015 12:25 am
There are several links to using AD as a Radius Server for Hotspot, AAA etc
Here is one...... http://wiki.mikrotik.com/wiki/AAA_with_Active_Directory
DLNoah is correct about the reverse encryption - so you need to weigh up if you want to do this.
We use this IAS feature for Hotspot authentication at schools etc.
Note IAS was renamed NPS (Network Policy Server) in Windows Server 2008 :D
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
pakfar
Tue Jan 27, 2015 11:11 am
I need ppp authentication with AD (user manager sync with AD)
it`s Possible?
Users browsing this forum: No registered users and 81 guests
