nomercy14
Routerboard with POE in and POE out
Mon Jan 26, 2015 4:55 pm
Hello all,
I have a question in case someone can help. I am searching for a routerboard device that has POE in and POE out in the same time.
I have a power supply in the house and an ethernet cable that powers on an RB912 on the roof. Since its impossible to pass a second cable I am trying to find a solution so that a device that can be powered on by one power supply and in the same time it can provide POE out to a second device.
If anyone has any idea please let me know.
Thank you in advanced.
honzam
Re: Routerboard with POE in and POE out
Mon Jan 26, 2015 6:40 pm
Hello there are three devices with poe IN and POE out in the same time
RB951Ui - http://routerboard.com/RB951Ui-2HnD
and
mAP - http://routerboard.com/RBmAP2n
and
http://routerboard.com/RB2011UiAS-2HnD-IN
LAN, FTTx, Wireless. ISP operator
jarda
Mon Jan 26, 2015 8:13 pm
Or you can solder a bit maybe whatever 100mbit device with poe in.
Petzl
Mon Jan 26, 2015 11:58 pm
regular Omnitik on the roof with soldered ports ... not UPA model wich doesn't work verry well ...
jarda
Tue Jan 27, 2015 12:06 am
That's my way...
scampbell
Trainer
Trainer
Tue Jan 27, 2015 12:27 am
Also RB260GSP, RB750UP
And Omnitik UPA model - works ok for us but the LED's are mixed up which can confuse people :-)
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
nomercy14
Tue Jan 27, 2015 1:30 pm
Thank you all for your replies! I will have a look to them.
One question only, what does it mean soldered ports?
jarda
Wed Jan 28, 2015 9:14 pm
scampbell
Trainer
Trainer
Thu Jan 29, 2015 2:25 am
Interesting. I have an Omnitik with an SXT5 Lite working at one recent plus another with RB433 and QRT5 working so maybe some models (manufacturing runs) work better than others ?
___________________
hennotaht
Tue Dec 11, 2018 12:04 am
Is there anything which has Poe In + Poe Out + 5GHz and compact enclosure and power efficient, so that I can run a "single" Ethernet cable (running to Poe in port and continuing on Poe out port to the next device) and put one device on every room to create a small 5GHz hotspot in each room?
hennotaht
Tue Dec 11, 2018 12:11 am
https://mikrotik.com/product/cap_ac
Although I'm not sure if they can be daisy chained together since its Poe In and Poe Out use different standards.
Users browsing this forum: No registered users and 94 guests
