Jeanluck
PowerBox PoE question for Mikrotik
Tue Feb 03, 2015 2:11 pm
If the input energy is in ether1 by poe, the limit remains at 2.2A for the four ether poe outs and 1A for each one?
That is, the use of ether1 poe has capacity restrictions of energy with respect to the standard power adapter? is limited at 1A input? (and therefore the limite of 1A is for the four poe outputs?)
InoX
Re: PowerBox PoE question for Mikrotik
Tue Feb 03, 2015 10:57 pm
Abouat what product are you talking about?
Jeanluck
Tue Feb 03, 2015 11:41 pm
Jeanluck
Thu Feb 05, 2015 11:59 pm
please, Mikrotik support, can you answer the question?
InoX
Fri Feb 06, 2015 12:14 am
I belive you must provide power with jack to power all the 4 remaining ports.
Jeanluck
Fri Feb 06, 2015 11:58 am
So I think too ... Mikrotik, stablish this please.
But in that case, if outdoor .... Is it logical?
If outdoor cable jack will not be long enough.
And if we use RJ45 and there are restrictions, this product is not valid for me....
normis
Fri Feb 06, 2015 12:00 pm
limits does not change depending on how you power the router
Jeanluck
Fri Feb 06, 2015 12:03 pm
So if I connect by passive PoE, the same energy source that powers the Jack, I can do exactly the same use?
InoX
Sat Feb 07, 2015 2:46 am
Today i tried to power an RB260GSP in poe port1 and power 3 radios, it didn't worked. The radios power compsuntion is 3.665W 3.034W 3.385W. PoE Current 153mA 133mA 142mA. So it cant provide 500mA total on 3 ports.
It only worked with DC jack.
Jeanluck
Sat Feb 07, 2015 12:12 pm
It is strange, because 260SP has a limit of 1A in each port, so the limit should be 1A for ALL ports in the wors case (not 500ma).
Supposedly Port1-PoE In would accept only 1A.
And Normis says in this post that is the same (PoE / jack). But PowerBox is outdoor.... maybe that it has a different design...
Mikrotik, can you give information about this?
chalan
Sat May 02, 2015 10:47 am
did you try to check the Port1 PoE In Long Cable and apply? i was trying to power with 260gsp (with power on port1, no jack) only one sxt (port5) and it did not work, so i check the Port1 PoE In Long Cable apply and suddenly its working well...
drdedus
Sat Jul 09, 2016 12:20 am
is there any news for new gigabit version of outdoor power box?
Users browsing this forum: No registered users and 116 guests
