MUM Europe 2020
realtime
10Gb VMXNET3 driver support request
Sat Feb 14, 2015 8:34 pm
I need that mikrotik to support 10Gb VMWARE VMXNET3 driver. My network become bigger, I am using more mikrotik routers (SXT2.4-5, AC....), and the gatways for all them are 4pcs of CCR1036. CCR1036 cant NAT big trafic(700-800Mbps) properly. So I have HP server (2CPU-each 6core ) ESXi 5.5 installed with 10Gb port in wich i need to run Router OS with VMXNET3 network card for the further development of the network.
IntrusDave
Re: 10Gb VMXNET3 driver support request
Sat Feb 14, 2015 8:45 pm
+1 for me
My largest network uses a quad core Xeon running ESXi 5.5 for routing. I would love the VMXNET3 support. As well as the rest of the tools.
David Joyce
Network & Security Engineer
Intrus Technologies, LLC.
Rancho Cucamonga, CA, USA
class889
Thu Feb 19, 2015 12:21 pm
i'd love that as well!
x7007
Thu Feb 19, 2015 6:42 pm
Me too , want the options
plentyofbug
Thu Feb 19, 2015 9:24 pm
+1 mee too!
realtime
Wed Mar 04, 2015 3:04 pm
Last test results. I got 5 GBit on the E1000 ethernet driver. Everything are shown on the pictures.
bajodel
Long time Member
Long time Member
Wed Mar 04, 2015 4:25 pm
Could you tell which 10 Gbit SFP+ physical adapter and which SFP+ module do you use ?
realtime
Wed Mar 04, 2015 4:48 pm
Broadcom NetXtreame II BCM57712
I don't use SPF module at moment. The servers connected directly with SFP+ DAC cable. Like this http://www.sfpex.com/image/cache/data/p ... 00x500.jpg
realtime
Wed Aug 19, 2015 8:42 pm
Hallelujah!
What's new in 6.31 (2015-Aug-14 15:42):
*) demo mode of Cloud Hosted Router (CHR) added
*) chr - added x86_64 image for use in virtual environments
*) chr - added support for VMware SCSI virtual disks
*) chr - added support for VMware vmxnet3 network card
*) chr - added support for HyperV SCSI disks
*) chr - added support for HyperV Ethernet interfaces
*) chr - added support for virtio disks
Thanks to mikrotik TEAM!!!
net adapter added!
so.. next question :) when do mikrotik best CPU usage results on x86 ? :) look like local bandwith test (to 127.0.0.1 or between 2 virtual mashines connected with virtual switch) more than 2.7Gb/s ?
because 10gbe net adapter must work with 10gbe bandwidth :)
for example bandwith between two debian virtual mashines is about 150Gbit (iperf 10 sessions, standart packet size)
janisk
Thu Aug 20, 2015 8:49 am
Bandwith-test in RouterOS is not very efficient way on how to generate traffic. Anyway, you can configure RPS and assign CPUs directly to IRQ that is working with the interface to optimize for performance if you are not satisfied. Later on when CHR has licensing available we will be able to properly test speed it can provide on x86_64 kernel.
realtime
Fri Aug 21, 2015 10:53 pm
I usually disable RPC.
Tell me please how to set up a x86_64 mikrotik in virtual machine for maximum throughput in bridge mode? I will test throughput between two debian machines and mikrotik bridge in the middle
AlexS
Mon Aug 24, 2015 9:33 am
I saw this a bit late.
I have tried to install vmxnet3 nic and well it doesn't show up in the interface interface.
I need to move to vmxnet3 as the input buffer for the e1000 is to small, I have a very bursty multicast service that drops packets on the E1000. Had to move to a hand built linux box with a vmxnet3 nic.
normis
Mon Aug 24, 2015 1:16 pm
The change is only for CHR http://forum.mikrotik.com/viewtopic.php?f=21&t=98981
Not for install from ISO
realtime
Thu Aug 27, 2015 12:17 am
abc
realtime
Thu Aug 27, 2015 1:16 am
Dear Normis what about throughput over mikrotik in CHR in simple bridge mode or how many traffic can be NAT-ed in licensed CHR? For example creating server with one CPU and 2000 Mhz.
Users browsing this forum: anav and 139 guests
