MUM Europe 2020
thecoder
System Error sending email timeout occurred
Fri Feb 20, 2015 9:08 am
I put this Script into Mikrotik :
:log info "backup beginning now"
:local backupfile ([/system identity get name] . "-" . [/system clock get time])
/tool user-manager database save name=$backupfile
:log info "backup pausing for 25s"
:delay 25s
:log info "backup being emailed"
/tool e-mail send to="moon002233@gmail.com" start=yes subject=([/system identity get name] . \
" User-Manager Backup") file=$backupfile
:log info "backup finished"
:delay 50s;
/file remove $backupfile;
:log info message=fileremoved
and I have messege error :
Error sending e-mail ... timeout occured
Can anyone explain what is the problem ?
thanx
Rudios
Forum Veteran
Forum Veteran
Re: System Error sending email timeout occurred
Fri Feb 20, 2015 12:34 pm
How are your email settings?
Server, username etc.
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
satman1w
Fri Feb 20, 2015 3:28 pm
:delay 25s
:delay 50s;
thanx
#Backup_send-mail V.1.0 [20130330]
:local mailsender ([/system identity get name]."@domain.com");
:local mailrec *your.email@domain.com*;
:local mailpass *mailpassword*;
:local mailbody "B.A.C.K.U.P.";
:local mailserver [:resolve *your-mailserver.domain.com*];
:local mailuser *user@domain.com*;
:local mailsubject ("Backup from /".[/system identity get name]."/".[/system clock get date]."/".[/system clock get time]);
:local backupfile ([/system identity get name].".backup");
/system backup save name=[/system identity get name];
:log info "----- Backup Created";
:delay 1000ms;
/tool e-mail send from=$mailsender to=$mailrec subject=$mailsubject body=$mailbody server=$mailserver user=$mailuser password=$mailpass file=$backupfile;
:log info "----- Backup Sent to $mailrec";
replace:
*your.email@domain.com..* - with receivers mail address (without "*")
*your-mailserver.domain.com* - with name of mailserver that will send the mail
*user@domain.com* - with username to log on to the mailserver
*mailpassword* - with password used to logon to the mailserver
that's it !
thecoder
Fri Feb 20, 2015 3:34 pm
My email settings is correct
becuase I sent an email form inside mikrotik and it is working
and I will try this new script
thanx
thecoder
Fri Feb 20, 2015 4:25 pm
:delay 25s
:delay 50s;
thanx
:delay 1000ms;
replace:
*your.email@domain.com....* - with receivers mail address (without "*")
that's it !
I put this script , and it show me this message :
like message with past script
I tried to send backup file manual, and I went to System > Email
and I make attach for file backup
and it give me same message
I notice all the script work good , but when it arrived to load backup file to attached , it show the message
I thought because size of backup file, but the size is 800kb
karincanet
Fri Feb 20, 2015 4:35 pm
I use this backup script and works fine. Also .rsc file compatible for all mikrotik devices.
/export file=("backup-" . \
[:pick [/system clock get date] 7 11] . [:pick [/system clock get date] 0 3] . [:pick [/system clock get date] 4 6])
/tool e-mail send to="TO MAIL ADRESS" subject=("System Backup " . \
[/system clock get date]) file=("backup-" . [:pick [/system clock get date] 7 11] . \
[:pick [/system clock get date] 0 3] . [:pick [/system clock get date] 4 6] . ".rsc")
:delay 10;
/file rem [/file find name=("backup-" . [:pick [/system clock get date] 7 11] . \
[:pick [/system clock get date] 0 3] . [:pick [/system clock get date] 4 6] . ".rsc")]
:log info ("System Backup emailed at " . [/sys cl get time] . " " . [/sys cl get date])
thecoder
Mon Feb 23, 2015 12:23 am
your Script for Mikrotik System backup
and My Script for user manger bakup
as I said before the problem not in the Script
because I saw the log , and it is work very good
but when it arrived to load backup user manger , to attached to my email
It failed , I don't know what the reason?
eworm
Mon Mar 02, 2015 11:49 am
Looks like I am effected, too.
Sending e-mail used to work up to and including RouterOS 6.25. My last backup via e-mail is from feb/02/2015.
I updated to RouterOS on feb/04/2015. After that I did not receive a mail from my routerboards.
RouterOS logs:
10:37:02 system,e-mail,error Error sending e-mail <Testmail>: timeout occured
While mailserver logs:
Mar 02 10:37:02 mx postfix/smtpd[16003]: connect from unknown[xx.xx.xx.xx]
Mar 02 10:37:02 mx postfix/smtpd[16003]: disconnect from unknown[xx.xx.xx.xx]
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
strods
Thu Mar 19, 2015 7:36 am
At least in my test configuration exact same script is working correctly:
1) Is this command executed:
*) Through console;
*) Through Script running it form console;
*) Through Script running it by pressing button in Winbox;
*) Through Script running it by Scheduler?
2) What is the size of attached file?
3) What kind of policy options are enabled if command is executed from Script?
4) What kind of policy options are enabled if command is executed from Scheduler?
eworm
Thu Mar 19, 2015 10:59 am
For me this is not related to scripts. Just sending a mail from terminal fails:
[admin@carpo] > /system routerboard print
       routerboard: yes
             model: 750GL
     serial-number: 467A0XXXXXXX
  current-firmware: 3.22
  upgrade-firmware: 3.22
[admin@carpo] > /system package print
Flags: X - disabled
 #   NAME                    VERSION        SCHEDULED
 0   system                  6.28rc14
 1   ipv6                    6.28rc14
 2   advanced-tools          6.28rc14
 3   ntp                     6.28rc14
 4   security                6.28rc14
[admin@carpo] > /tool e-mail print
    address: 10.XX.XX.XX
       port: 587
  start-tls: yes
       user: smtp-only@XXXXX.XX
   password: XXXXXXXXXX
[admin@carpo] > /tool e-mail send body=Test subject=Testmail... to=mail@XXXXX.XX
[admin@carpo] > /log print
09:50:22 system,e-mail,error Error sending e-mail <Testmail...>: timeout occured
Of course it fails from script as well. ;)
The mails server address is private and accessible via VPN connection.
eworm
Wed Mar 25, 2015 10:32 pm
I thought the connection is encrypted and did not try to dump it so far... Just did that now. And guess what? No encryption. :roll:
RSET
220 mx.xxxxxxx.de ESMTP Postfix
530 5.7.0 Must issue a STARTTLS command first
QUIT
221 2.0.0 Bye
Red ist from RouterBoard, blue is from mailserver.
The connection is started with RSET, which the mailserver does not like.
mgisbers
Fri Mar 27, 2015 4:22 pm
RFC 3207:
A SMTP server that is not publicly referenced may choose to require
that the client perform a TLS negotiation before accepting any
commands. In this case, the server SHOULD return the reply code:
530 Must issue a STARTTLS command first
to every command other than NOOP, EHLO, STARTTLS, or QUIT.
If the client and server are using the ENHANCEDSTATUSCODES
ESMTP extension [RFC2034], the status code to be returned
SHOULD be 5.7.0.
Maybe the problem is that you try to connect to the submission port (587) which does not allow other commands than those referenced in RFC 3207.
Please try to connect using port 25 on.
But, anyway, RouterOS should work using port 587 also.
Regards,
Michael
mgisbers
Fri Mar 27, 2015 4:26 pm
RFC 3207:
SHOULD be 5.7.0.
Regards,
Michael
eworm
Mon Mar 30, 2015 5:56 pm
Sending on port 25 fails as well:
220 mx.xxxxx.de ESMTP Postfix
RSET
250 2.0.0 Ok
QUIT
221 2.0.0 Bye
janisk
Wed Apr 01, 2015 3:14 pm
if you can give us details for us to try to log in we would appreciate that. So, if you can, send them to support@mikrotik.com reference this post.
eworm
Thu Apr 02, 2015 3:37 pm
This is fixed in version 6.28rc20. Thanks a lot MikroTik!
theadmiral
Sun May 17, 2015 3:51 am
Thank you, version 6.28 did correct the short smtp connection timeout problem. However, other short timeouts now exist within the communication session. On high latency connections (or those with intentional anti-spam post-connection delays), if RouterOS 's e-mail tool does not receive a reply within 15 seconds, it will abort the session without generating any error message or attempting a retry. This specific problem only popped up in 6.28.
A 15 second response delay appears to be enough to trigger the behavior. This can be duplicated by configuring a Postfix based mail server using the "sleep" directive. For example the e-mail tool will drop out (without generating syslog error messages) after sending "RCPT TO:" with the remote Postfix mail server configured as follows:
smtpd_recipient_restrictions =
permit_mynetworks,
permit_sasl_authenticated,
sleep 16,
reject_unauth_destination,
reject_unauth_pipelining,
reject_invalid_helo_hostname,
reject_non_fqdn_sender,
reject_non_fqdn_recipient,
(etc..)
This is not a critical problem (since removing the sleep line resolves the problem); however, it does introduce a new, undesirable behavior. Increasing the time-out or adding a debug syslog event would be most useful.
Thanks again for fixing the original connection timeout bug :-)
Thanks Much.
Users browsing this forum: gramels, l0ft13 and 155 guests
