jmay
Billing software with Radius support
Wed Mar 11, 2015 9:41 pm
I'm looking for a good solution here, I've been given a budget of 10 grand or less. Since we have a mixed variety of client devices radius would work the best for us and rather than a seperate system I'd really like a billing solution that has it built in. What are you all using?
ZeroByte
Re: Billing software with Radius support
Wed Mar 11, 2015 9:50 pm
We used billmax at a previous job of mine. (company still exists - I just got a better job, haha)
I think my experience with it was not the best one - it wasn't set up like the software was designed to be, but even so, it seemed to do pretty well.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
lambert
Long time Member
Long time Member
Thu Mar 12, 2015 12:01 am
If you are a typical Wireless ISP, off the top of my head:
http://freeside.biz/freeside
http://wispmon.com
http://powercode.com
http://visp.net
http://azotel.com
http://ispbilling.com
http://billmax.com
There are probably other options.
If you just want to do hotspot billing, there are other packages focused on that. I think you can also use at least some of the above packages for hotspots, but have no personal experience with hotspots.
Hammy
Forum Veteran
Forum Veteran
Thu Mar 12, 2015 12:14 pm
I use wispmon, but in addition to the above there's swiftfox.
Users browsing this forum: Baidu [Spider], Google [Bot] and 54 guests
