ahlai
how to limit the connection number of client
Sun Jul 09, 2006 1:33 am
In my lan ,there are only 9 computer,
but always have 3000 connections,/ip/firewall/connection/print,i can see.
how to limit the connection number of each client?
thanks
sergejs
Sun Jul 09, 2006 9:11 am
/ip firewall filter add chain=forward protocol=tcp tcp-flags=syn connection-limit=101,32 action=drop
This rule will allow 100 TCP simultaneous connection per network user.
zong
Mon Jul 10, 2006 8:06 am
Hii....
I am using MT 2.9.6
using this rule but client can open more than 5 connections per Ip address.
/ip firewall filter add chain=forward protocol=tcp tcp-flags=syn connection-limit=4,24 action=drop
here my config
local : 192.168.168.200 netmask : 255.255.255.0
public : 10.97.20.200 netmask : 255.255.0.0
ip firewall nat> add chain=srcnat action=masquerade out-interface=Public
pls assist
sergejs
Mon Jul 10, 2006 8:08 am
1) Upgrade your router to the latest MikroTik RouterOS version.
2) your rule allows 3 connections per network.
4 - is allowed connections, 24 - subnet mask.
Change connection-limit configuration.
zong
Mon Jul 10, 2006 8:18 am
so if using this ver 2.9.6 can not limit connection per ip address ?
mhhh :shock:
sergejs
Mon Jul 10, 2006 9:02 am
It should work, however it's recommended to ugprade.
Note, given rule will limit TCP connections.
zong
Mon Jul 10, 2006 12:20 pm
what the correct rule for MT 2.9.6 ?
thx
:lol:
normis
Mon Jul 10, 2006 12:23 pm
you should consider upgrading if something doesn't work for you
Users browsing this forum: Baidu [Spider], Bokous, Rebel1 and 31 guests
