eworm
[Feature request] conditional dhcp options
Wed Apr 08, 2015 12:59 am
Hello everybody,
currently RouterOS supports adding dhcp options and it does send these only when requested from client. What I need is to send conditional options based on information the client sends.
My first example is PXE booting. Depending on what the client is, supports or what architecture it is based on I need to send different options. This is configuration snippet for ISC dhcpd:
# Declare the iPXE option space
option space ipxe;
option ipxe-encap-opts code 175 = encapsulate ipxe;
# iPXE feature flags, set in DHCP request packet
option ipxe.http      code 19 = unsigned integer 8;
option ipxe.bzimage   code 24 = unsigned integer 8;
option ipxe.pxe       code 33 = unsigned integer 8;
option ipxe.elf       code 34 = unsigned integer 8;
option ipxe.efi       code 36 = unsigned integer 8;
option ipxe.menu      code 39 = unsigned integer 8;
# Other useful general options
option arch code 93 = unsigned integer 16;
class "PXEClient" {
        match if substring(option vendor-class-identifier, 0, 9) = "PXEClient";
        allow booting;
        allow bootp;
        next-server 10.0.0.1;
        # Make sure the iPXE we're loading supports what we need,
        # if not load a full-featured version.
        if exists ipxe.http
          and exists ipxe.menu
          and ((exists ipxe.pxe
              and exists ipxe.bzimage
              and exists ipxe.elf)
            or (exists ipxe.efi)) {
                # Everything is fine, just send the boot configuration file.
                filename "http://10.0.0.1:3928/default.ipxe";
        } elsif exists user-class and option user-class = "iPXE" {
                # We're already using iPXE, but not a feature-full version,
                # and possibly an out-of-date version from ROM, so load a more
                # complete version with native drivers.
                if option arch = 00:06 {
                        filename "/ipxe/efi-i386.efi";
                } elsif option arch = 00:07 {
                        filename "/ipxe/efi-x86_64.efi";
                } else {
                        filename "/ipxe/ipxe.pxe";
        } elsif exists user-class and option user-class = "gPXE" {
                # If someone has an old version of gPXE burned into their ROM,
                # load a more recent iPXE
        } elsif option arch = 00:06 {
        } else {
This is kind of complex... It uses information from vendor-class-identifier, ipxe option space and architecture (general option code 93). But having a solution for that in RouterOS would be really great.
Another example is a mix of VoIP phones. Depending on the manufacturer I have to send different options...
# Siemens Opti Stage IP Phones
class "OptiIpPhone" {
        match if option vendor-class-identifier = "OptiIpPhone";
        option vendor-encapsulated-options 01:07:53:69:65:6D:65:6E:73:02:...;
 # Lync Phone
class "CPE-OCPHONE" {
        match if option vendor-class-identifier = "CPE-OCPHONE";
        option vendor-encapsulated-options 01:0B:43:50:45:...;
class "MS-UC-Client" {
        match if option vendor-class-identifier = "MS-UC-Client";
        option vendor-encapsulated-options 01:0C:4d:53:2d:...;
Thanks for your excellent devices and a great operating system for routers!
Best regards,
Chris
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
jinzhanhua
Re: [Feature request] conditional dhcp options
Sun Nov 22, 2015 12:49 pm
Hi, I have simular custom DHCP options too.
If DHCP->Leases has static item of DHCP client and this item has custom DHCP options, DHCP Server could offer this custom DHCP options to DHCP client even if DHCP client didn't send these options during DHCP Discovery package.
Thanks!
sw25481
Mon Jan 18, 2016 1:51 am
I have a simmilar, all be it simplified requirement that this would be great for.
I want to be able to PXEboot systems with traditional BIOS and systems with EFI. Each needs a different boot file. You would usually enable this with
filename "pxelinux/bootia32.efi";
} else {
filename "pxelinux/pxelinux.0";
I would lover RouterOS to support this
marianob85
Wed Feb 08, 2017 9:50 pm
Is there any progress with this issue ? I'm also will be grateful for possibility returning different boot file depends of pxeboot system.
sebus
Mon Mar 13, 2017 9:30 am
Anything ever came out of it?
sebus
sebus
Wed Mar 15, 2017 3:29 pm
Nobody?
biatche
Sun Mar 19, 2017 3:13 pm
This is one attitude i dislike about mikrotik. They won't reply even when faced with important bugs. Maybe they only communicate with people they know. Disappointing.
But I'm so much so looking forward to this feature. We should have modern networking booting for modern times.
dnsmasq supports conditions, isc dhcpd supports it, even microsoft dhcp probably supports it.
ziegenberg
Mon Mar 20, 2017 8:42 am
Did you shoot them a mail at support@mikrotik.com? They always answer those mails and that's the address to turn to when you have:
  • found a bug
  • a feature request
  • questions not suitable for the forum
  • the need for a defintive answer
greetings, Daniel
biatche
Tue Mar 21, 2017 12:25 am
  • found a bug
  • a feature request
greetings, Daniel
On conditional dhcp? no. Did send a mail on issues prevalent with bridge+vlan on 6.38.5 to which i havent received a reply after a week. How about you send them an email on this on 'our' behalf and see if they do actually reply. (Since they always reply to you) You could then let us know of the wonderful news.
ziegenberg
Fri Mar 24, 2017 12:47 pm
Hey!
I did write to them and they answered in less than a day. They told me the same jinzhanhua did some posts above. "DHCP lease menu allows you to set different DHCP option or option set for specific client."
Well, I wasn't pleased with the answer and asked more specifically for "rule-based conditional DHCP options". They replied "We will see what we can do about it."
So this is probably not the "wonderful news" you were looking for, but they replied.
If you want to refer to my inquiry you may use the following ticket number: Ticket#2017032222001004. If they see more people requesting certain features it helps them decide what to implement next.
greetings, Daniel
biatche
Mon Mar 27, 2017 1:06 pm
Hey!
greetings, Daniel
Heh I don't know, but that's great that they do reply to you promptly. Thanks for helping those of us here who wish to see this feature.
So dear mikrotik, hoping to see a more complete dhcp/dns server package in routeros, like dnsmasq/isc dhcpd.
ziegenberg
Mon Mar 27, 2017 1:12 pm
As I mentioned before: write them an email. Refere to the ticketnumber. It has much more of an effect.
greetings, Daniel
thomaz40
Sat Jun 30, 2018 10:58 am
Any solution?
I think so, because I managed with these configurations, boot via legacy and uefi in a virtual machine, without having to manually change the d boot file.
Sorry for the English, by google translator.
add address-pool=dhcp_pool0 bootp-support=dynamic disabled=no interface=\
ether5 lease-time=8h10m name=dhcp1
/ip dhcp-server option
add code=67 name=bios value="'undionly.kpxe'"
add code=67 name=uefi value="'ipxe.efi'"
/ip dhcp-server option sets
add name=legacy options=bios
add address=10.100.100.0/24 boot-file-name=undionly.kpxe dhcp-option=uefi \
dns-server=10.100.100.1 domain=mkhome.lan.br gateway=10.100.100.1 \
next-server=10.100.100.252
eworm
Fri Dec 14, 2018 1:09 am
You define an option set named "legacy", but it is not used anywhere. I do not think this works.
shivansps
Fri Dec 28, 2018 11:29 pm
You can use DHCP option 67 to change the boot file name, in fact ive been using that to easily change PXE and UEFI boot mode from winbox, and yes you can set a dhcp option to one filename and having a dhcp option set pointing to the other one(what i think he was missing on the last command) active at the same time on a network but it dosent work.
velonet
Mon Jul 08, 2019 1:21 pm
Hey, for those coming across this post, see the latest (at this time) changelog for RouterOS:
dhcpv4-server - added "vendor-class-id" matcher (CLI only);
source: https://mikrotik.com/download/changelog ... 486e7f63b5
Your wishes might have been fulfilled. (haven't tested it myself).
eworm
Mon Jul 08, 2019 3:35 pm
That's a step forward, but not a solution. We need the matcher for the architecture.
karloch
Sun Aug 18, 2019 1:25 pm
I am also looking forward this feature so I can network boot EFI, BIOS and amd64/i386/arm64 architectures.
EgorL
Tue Oct 15, 2019 8:38 am
so am i
hackclub
Mon Oct 21, 2019 8:55 pm
I am also looking forward this feature so I can network boot EFI , BIOS
Users browsing this forum: MSN [Bot] and 73 guests
