vik1988
Old RB750 upgraded to RB 750r2 Hex Lite?
Mon Apr 13, 2015 5:28 pm
Recently, we received new RB 750r2(QCA9531-BL3A). Not found any documentation of this model anywhere.
Mikrotik Team Please provide the list of upcoming models in QCA9531.
Vikas Kumar Gupta
If you Like my post then add KARMA
skype- kumarvikas_gupta
sergejs
Re: Old RB750 upgraded to RB 750r2 Hex Lite?
Tue Apr 14, 2015 1:25 pm
Congratulations you received new improved RB750r2. More information about it will follow.
jarda
Tue Apr 14, 2015 4:26 pm
Oh. How is it possible?
vik1988
Re: Old RB750 degraded to RB 750r2 Hex Lite?
Wed Apr 15, 2015 12:43 pm
To Sergejs :
You have degraded/upgraded on your own. No one knows about this product till now. and no information received from your newsletter for this product.
You did a big change of chipset and look in your existing product. Your website still showing AR7241 based RB 750.
I need to send all information of this product again to my customers. :( :( :(
You have not intimated to the distributors before.
Vikas Kumar Gupta
honzam
Wed Apr 15, 2015 7:16 pm
It have CPU - 650Mhz like hAP ?
LAN, FTTx, Wireless. ISP operator
vik1988
Wed Apr 22, 2015 10:57 am
yup.
Vikas Kumar Gupta
simej
Mon Apr 27, 2015 9:48 pm
How to backup configuration from terminal in Flash folder so they don't get deleted when command
/system reset-configuration no-defaults=yes skip-backup=yes keep-users=no
is executed?
Antz
Wed May 06, 2015 9:59 am
For anyone still wondering about the specification for this new RouterBoard. This is from a freshly unboxed unit.
[admin@MikroTik] /system> routerboard print
       routerboard: yes
             model: RouterBOARD 750 r2
     serial-number: ##############
  current-firmware: 3.19
  upgrade-firmware: 3.19
[admin@MikroTik] /system> license print
  software-id: V20F-YC62
       nlevel: 4
     features:
[admin@MikroTik] /system> resource print
                   uptime: 3m
                  version: 6.25
               build-time: Jan/19/2015 10:11:08
              free-memory: 47.0MiB
             total-memory: 64.0MiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 650MHz
                 cpu-load: 0%
           free-hdd-space: 5.2MiB
          total-hdd-space: 16.0MiB
  write-sect-since-reboot: 615
         write-sect-total: 1179
               bad-blocks: 0%
        architecture-name: mipsbe
               board-name: RB750r2
                 platform: MikroTik
LatinSuD
Wed May 13, 2015 12:58 pm
What's WRONG with these new boards?
- It looks like we now have to use "flash/" subdirectory and the root filesystem is some kind of ram disk (nobody told me, and had to find out the hard way).
- We've got four of them and for some of them they just don't work. Or after resetting tens of times they might work for a while...
- Another bug. Put this into test.rsc:
set [find] master-port=none
set [ find default-name=ether1 ] name=wan1 master-port=none
set [ find default-name=ether2 ] name=wan2 master-port=none
set [ find default-name=ether3 ] name=LAN master-port=none
set [ find default-name=ether4 ] name=lan1 master-port=LAN
set [ find default-name=ether5 ] name=lan2 master-port=LAN
And now run
/system reset-configuration no-defaults=yes run-after-reset=flash/test.rsc
The result is that ethernet LED don't work anymore. Rebooting does not help. The only solution is to reset.
jimmyz
Sat Jun 27, 2015 10:31 am
just put my hands on this one:
                   uptime: 1m50s
                  version: 6.29.1
               build-time: Jun/01/2015 13:30:35
              free-memory: 47.3MiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
                 cpu-load: 2%
  write-sect-since-reboot: 58
         write-sect-total: 1738
               bad-blocks: 0%
               board-name: hEX lite
                 platform: MikroTik
[admin@MikroTik] /system routerboard> print
       routerboard: yes
     serial-number: 58A9xxxxxxxx
  current-firmware: 3.24
  upgrade-firmware: 3.24
Should I set cpu frequency to 850MHz
/system routerboard settings set cpu-frequency=850MHz
or not?
Mikegyver42
Fri Jun 23, 2017 3:20 pm
What's WRONG with these new boards?The result is that ethernet LED don't work anymore. Rebooting does not help. The only solution is to reset.
Is there any other solution to restore the led functionnality ?
Users browsing this forum: Baidu [Spider], Bing [Bot], Google Adsense [Bot] and 104 guests
