kolorasta
Bandwidth limit to a group of IPs. Is it possible?
Mon Jul 10, 2006 11:47 pm
i read this article (http://wiki.mikrotik.com/wiki/PCQ_Examples) and i have the following question:
is it possible to shape traffic like is shown in this image?
What i want to do is assign certain speed limits for specific computers (192.168.0.30, 192.168.0.31, 192.168.0.50) and then assign certain bandwidth to a group of computers... in the picture, share 512kbps upload/512kbps download between 192.168.0.33, 192.168.0.35 and 192.168.0.40.
jo2jo
Tue Jul 11, 2006 7:34 am
yes you need to look into firewall -> mangle rules with the action packet mark....then setup up a simple queue under "queues" to grab and shape the packets with the marking and criteria u set up in the mangle rules.
sergejs
Tue Jul 11, 2006 7:47 am
kolorasta,'ip firewall address-list' feature will help you to create user groups, and don't apply mangle rule per each user fromthe same group.
kolorasta
Fri Aug 18, 2006 11:35 pm
I have different clients with different services...
i have ip/mac combinations (not ppoe or something like that)
i want to make for example:
List: ip
Residential: 172.16.0.31,172.16.0.35,172.16.0.54,172.16.0.40
Corporative: 172.16.030,172.16.0.100,172.16.0.60
then i want to apply different upload/download speed and QoS to these groups... I have several goups (6 or more) and some of these groups has 40 ips or more...
in list i couldn't put ips in that way (asorted) only let me put range (172.16.0.30-172.16.0.40) or specifying subnet (172.16.0.1/21)
advantz
Sat Aug 19, 2006 3:41 am
It can be done with mangle + address list + queue tree
That's why I requested simple queue that can use "address-list" feature to
simplified this...
because with mangle only mark one way e.g. upstream or downstream, you need to mangle both ways
fatonk
Sat Aug 19, 2006 2:13 pm
It is possible to use PCQ for that kind of setup, but to be more elegant solution, it would be good that /24 subnet to assign i order like:
Residential 172.16.0.1 -> 172.16.0.30
Corporative 172.16.0.33 -> 172.16.0.60 etc and so one
with this kind of address allocation you can mangle traffic based on range (subnet), for residential 172.16.0.0/27 for corporative 172.16.0.32/27 and so one, and than you can apply the mangle rules into a queuing rule in this case PCQ type, tree.
I will post you a configuration that works for me with no problem.
Regards
samsoft08
Long time Member
Long time Member
Sat Aug 19, 2006 5:31 pm
i think as in the manual example , you can use PCQ for upstream and downstream by assigning dst-port and src-port in the Q type , so u have to use mangle once , it will mangle both ways at the same time .
kolorasta
Sat Aug 19, 2006 8:28 pm
Regards
ok ... thanks.. i wait for that configuration
fatonk
Sun Aug 20, 2006 12:51 am
OK, here we go :-)
This set-up works fine for me, with this configuration you can limit a p2p traffic to 56 Kbit for each IP of the subnet 172.16.0.0/27, and also the overall traffic will be limited to 128 UP and 256 DOWN and that per IP address of the above mentioned subnet. Here it is the configuration:
ip firewall mangle add chain=forward src-address=172.16.0.0/27 p2p=all-p2p action=mark-connection new-connection-mark=p2p_conn
ip firewall mangle add chain=forward src-address=172.16.0.0/27 connection-mark=p2p_conn action=mark-packet new-packet-mark=p2p
ip firewall mangle add chain=forward sr-address=172.16.0.0/27 connection-mark=!p2p_conn action=mark-packet new-packet-mark=other
queue type add name=p2p-Down kind=pcq pcq-rate=56000 pcq-limit=50 pcq-classifier=dst-address pcq-total-limit=2000
queue type add name=p2p-Up kind=pcq pcq-rate=56000 pcq-limit=50 pcq-classifier=src-address pcq-total-limit=2000
queue type add name=Down kind=pcq pcq-rate=262015 pcq-limit=50 pcq-classifier=dst-address pcq-total-limit=2000
queue type add name=Up kind=pcq pcq-rate=131072 pcq-limit=50 pcq-classifier=src-address pcq-total-limit=2000
queue tree add name=p2p-up parent=5.8Ghz packet-mark=p2p limit-at=0 queue=p2p-Up priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
queue tree add name=p2p-Down parent=ether1 packet-mark=p2p limit-at=0 queue=p2p-Down priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
queue tree add name=Upload parent=5.8Ghz packet-mark=other limit-at=0 queue=Up priority=1 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
queue tree add name=Download parent=ether1 packet-mark=other limit-at=0 queue=Down priority=1 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0
Reagrads
Faton
samsoft08
Long time Member
Long time Member
Sun Aug 20, 2006 1:37 am
i think you should use prerouting instead of using forward in the mangle
yudhi
Mon Aug 21, 2006 5:07 pm
Guys,
I have list of IPs allocation for our country used by local ISP in local exchange (lets call IIX), then other IPs out of that list are overseas.
I want to know how to configure :
- There are 2 group of users, 256K and 512K.
- Per user (per IP) for 256K group have minimum 5 Kbps to overseas up/down, burstable to 32 Kbps up and burstable 256 Kbps down.
- Per user (per IP) for 512K group have minimum 10 Kbps to overseas up/down, burstable to 32 Kbps up and burstable 512 Kbps down.
- Per user (per IP) for both group have minimum 5 Kbps to IIX up/down, burstable to 512 Kbps up/down.
Somebody could help me, please ?
Thanks.
miahac
Long time Member
Long time Member
Thu Aug 31, 2006 5:36 am
what did you use to draw that?
fatonk
Thu Aug 31, 2006 9:12 am
I think it is a microsoft office visio.
miahac
Long time Member
Long time Member
Thu Aug 31, 2006 5:33 pm
oh... $$$$$
pecahbelah
Re: Bandwidth limit to a group of IPs. Is it possible?
Tue Oct 31, 2006 8:34 pm
What i want to do is assign certain speed limits for a group of computers... in the picture
fatonk
Wed Nov 01, 2006 11:34 am
Is that bandwidth for the whole group, or it is for each host in that group.
Regards
Faton
tralala
Wed Nov 01, 2006 11:35 am
There is example in the manual (just read it all).
packet mark -> queue tree with pcq rate 0
or just simple queue with pcq rate 0
Its work, but the problem is that if full bandiwth is used, ping is jumping to around 100ms for all users. So its useless, and its better to avoid it.
Users browsing this forum: Bing [Bot], GoogleOther [Bot], mkx, Sddaw and 177 guests
