nasnsq
Accessing Clients throw DHCP router
Thu Apr 16, 2015 12:10 pm
Hi ,
I have a Mikrotik which works as PPPOE clients and providing internet service to couple of router each router have it's own DHCP server from Mikrotik i can monitor only the router and i have no access to the clients ? is there any way that i can reach the clients directly from my Mikrotik ?
thanks .
kiaunel
Thu Apr 16, 2015 2:53 pm
What kind of reaching do you want? Port forward on routers behind microtik if i understand corectly
nasnsq
Re: Accessing Clients throw DHCP router
Thu Apr 16, 2015 3:06 pm
reaching mean i can see users from Miktotik and control them , can you explain how should i make port forwarding in the router to my mikrotik ?
thanks .
ZeroByte
Thu Apr 16, 2015 4:07 pm
Do you want your ISP to tunnel through your router into your LAN to "see and control" your stuff?
I didn't think so.
Your users' routers aren't going to let you do that either.
-- if they're YOUR routers that you supply, then you're going to have to disable NAT on the client side, and assign a static route of IP addresses unique to each user, associated with each user's ppp secret, and finally do the NAT for all clients on your own router in stead.
(I'm not going to go into any more detail than that - good luck)
When given a spoon,
you should not cling to your fork.
The soup will get cold.
Users browsing this forum: Egert143, gergelyaki, MSN [Bot], Traveller and 199 guests
