MUM Europe 2020
spacemind
pppoe client on mikrotik with radius queues slow speed
Fri Apr 24, 2015 4:32 am
I´v been trying to figure out a speed problem in the past weeks, but i could not ...
I have 5 ppoe test devices connected to mikrotik ppoe server with radius authentication.
Here are my tests:
- Radius service setup with 60mbits down and 3mbits up
- Client gets 13mbits down and 2.8mbits up on oakla speed test and in mikrotik i see 12 to 16mbits down. (very slow download) I have checked and there is a queue for my test client with 60/3mbits limit.
- Radius service setup with unlimited download speed and 3mbits up
- Client gets more than 60mbits download and 2.8 mbits upload.
During all tests, mikrotik cpu does not exceed 30% and i tried with v6.18, v6.24, v6.27
I tried with different routers brands and only mikrotik is causing this problem.
Anyone has the same problem ? How to fix this ?
spacemind
Re: pppoe client on mikrotik with radius queues slow speed
Mon May 04, 2015 1:49 am
Any help on this guys ?
fuzzbawl
Wed May 06, 2015 6:42 pm
Create a new queue type of fifo (or modify an existing one) with Queue Size set to something more than 100 packets. Set your PPP profile to use that queue type.
spacemind
Wed May 06, 2015 7:50 pm
I changed the default queue to pfifo and packed size to 100 but i get the same problem.
Makoto
Tue May 12, 2015 5:02 pm
haveing the same problem , canout push more then 15 Mbit in download over pppoe!
Did you menage to fix it!?
Edit: pfifo with size 100 packets worked for me!
spacemind
Fri Oct 23, 2015 1:00 am
This problem keeps happening everytime.
queue speeds are correct in mikrotik but pppoe client that should have 40mbits only has 28mbits and without queue pppoe client goes up to 70mbits.
spacemind
Sat Nov 28, 2015 12:34 am
I got it working better with seting up the default-small queue pfifo with 100 packages.
Users browsing this forum: No registered users and 97 guests
