ners
Possible bug in RouterOS's SSH server
Fri May 01, 2015 6:52 pm
I am using VanDyke's SecureFX for accessing my boxes via SFTP.
However SecureFX fails to connect to a Mikrotik RouterOS device. At some point the connection process just stops.
People at VanDyke say there is a bug with Mikrotik's SSH server: it is sending a packet with an invalid "request-id" value.
Could you (the Mikrotik guys) please look into this? It should not be very hard to fix.
SecureCRT/SecureFX are very popular among system and network engineers.
I have attached a log file reflecting this issue.
sfx_733_810_trace9_mikrotik.log
DigitalBlueBiz
Trainer
Trainer
Re: Possible bug in RouterOS's SSH server
Sat May 02, 2015 12:13 am
Hi ners,
Mikrotik guys checks the forum quite often but your request can get lost due to high number of posts.
I strongly suggest you to send an email to support@mikrotik.com with your issue so it can get the correct attention.
If post is useful please "rate post positive"
Matteo Ferraroni
MTCNA - MTCWE - MTCTCE - MTCRE
Certified Trainer #TR0346
http://www.digital-blue.biz
IntrusDave
Sat May 02, 2015 7:09 am
I would begin by looking at your path MTU. Every ssh / ssl issue I have dealt with has been caused by a path MTU being less than 1500. Check your interfaces, VPN's, bridges, everything. I use SecureFX on Windows boxes and Forklift on my Macs with no sftp issues at all.
David Joyce
Network & Security Engineer
Intrus Technologies, LLC.
Rancho Cucamonga, CA, USA
ners
Mon May 04, 2015 12:58 am
I contacted VanDyke's support and after an investigation they told me
the following:
> the SSH server is sending a packet with an invalid SFTP request ID.
> Here is the malformed packet SecureFX receives from the server: 00
> 00 00 2c 0d 5e 00 00 00 00 00 00 00 15 00 00 00 11 65 73 2d 6d 75 00
> 00 00 08 00 00 00 00 00 00 00 00
> The data suggests that the server is attempting to send an
> UNSUPPORTED message (00 00 00 08) in response to SecureFX's
> STAT/REALPATH request. But, the server supplies an invalid request
> ID (73 2d 6d 75), in violation of the SFTP protocol. Rather than
> assume or guess the server's intention, SecureFX terminates the
> connection.
So this doesn't look like an MTU problem (also WinSCP connects fine)
Users browsing this forum: No registered users and 95 guests
