dipdip
CCR1016 to CCR1016 bandwidth test TCP throughput BAD
Thu May 07, 2015 12:26 am
Hi.
I got a Unit A, a CCR1016( 192.168.0.150/24) connected to Unit B,also a CCR1016 (192.168.0.151/24) which again connects to Unit C which is a 1100 AHx2 (192.168.0.152/24).
When doing a bandwidth test from Unit A to Unit C via Unit B I got TCP 382 Mbps and UDP 974 Mbps.
The ports are supposed to be gigabit ports, so why am I not getting gigabit TCP speeds?
Both CCR1016 are in bridge mode (ports 2,4) and the IP of the 1100 is configured on an ethernet port.
No firewall rules . no mangle.
CPU for the sending CCR is 6%. CPU for receiving 1100 is 64% max.
What can I do to get my TCP speed up ?
edgars
Thu May 07, 2015 1:54 am
Change interface queue types from hardware to ethernet-default see if that helps.
dipdip
Re: CCR1016 to CCR1016 bandwidth test TCP throughput BAD
Thu May 07, 2015 2:08 am
thanks edgars but unfortunately no differance.
dipdip
Thu May 07, 2015 7:53 pm
realy? no help? :(
pukkita
Trainer
Trainer
Thu May 07, 2015 8:32 pm
Are all up to date in terms of RouterOs version and firmware?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
chechito
Sun May 10, 2015 6:21 am
use profile to check the cpu usage per core
TrollMan
Sun May 10, 2015 11:57 am
If your running the built in bandwidth test then it's expected. Run iperf from 2 computers instead
dipdip
Mon May 11, 2015 5:30 pm
OS and firmware is the latest.
CCR CPU is 6%
CPU of the 1100 is 64 %
Users browsing this forum: Google [Bot] and 79 guests
