MUM Europe 2020
jfvelamoscoso
Trainer
Trainer
IP 31.6.71.253 & 31.6.71.254
Wed May 20, 2015 8:50 pm
I am getting on torch a lot of traffic upload to this ip:
31.6.71.253
31.6.71.254
But there is no user behind this router, looks like the router is uploading this information.
Does anyone know what service is uploading? or Why is this?
jfvelamoscoso@gmail.com
Network Engineer Noc Department
MTCNA, MTCTCE
If it helps please give some karma
pukkita
Trainer
Trainer
Re: IP 31.6.71.253 & 31.6.71.254
Wed May 20, 2015 9:05 pm
Do you have assigned ips in that range? to which ports does the traffic go? Its probably either network (port) probing or scanning; maybe your ISP has set routing improperly.
BTW there's a typo in your sig, guess you meant MTCTCE :D
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
jfvelamoscoso
Trainer
Trainer
Wed May 20, 2015 9:06 pm
I found also this IP
103.243.20.43
94.190.193.121
201.34.145.201
209.216.126.207
189.79.40.16
192.185.26.193
194.6.233.17
MTCNA, MTCTCE
jfvelamoscoso
Trainer
Trainer
Wed May 20, 2015 9:08 pm
This IP are found on Source address, and the destination is the router.
On ip firewall connections.
I can find different source porte but the destination port is always the same 53. This traffic is unexpected because as i said there is no host behind the router. Looks like the router is uploading all of this traffic
MTCNA, MTCTCE
pukkita
Trainer
Trainer
Wed May 20, 2015 9:10 pm
could you post a screenshot from ip > firewall > connections??
jfvelamoscoso
Trainer
Trainer
Wed May 20, 2015 9:11 pm
I forgot to tell the traffic is more than 3 Mbps which is too much for dns
MTCNA, MTCTCE
chechito
Wed May 20, 2015 9:15 pm
research the ip
www.ip2location.com
pukkita
Trainer
Trainer
Wed May 20, 2015 9:25 pm
chechito: it varies from day day... this morning were russian ips, right now are turkish, later may be chinese ips...
If your router is really exposed to the Internet (i.e. not an ADSL o FTTH line) a good firewall, that adds "probing" or port scanning source IPs to dynamic address lists for further firewall drop is mandatory.
jfvelamoscoso
Trainer
Trainer
Wed May 20, 2015 9:35 pm
I found the problem. My router was been used as a DNS Server and it has allowed request activate.
MTCNA, MTCTCE
chechito
Wed May 20, 2015 9:52 pm
Users browsing this forum: barracuda, selimadn, timotei and 93 guests
