Thalid
bridge problem
Sun May 24, 2015 7:32 pm
Trying make a bridge betwhen 2 sxt
Ap
add name=bridge1
set [ find default-name=ether1 ] name=ether1-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=\
    20/40mhz-ht-above disabled=no l2mtu=2290 mode=bridge name=wlan1-gateway \
    nv2-cell-radius=10 nv2-preshared-key=lollollol nv2-security=enabled ssid=\
    MikroTik wireless-protocol=nv2
/ip neighbor discovery
set wlan1-gateway discover=no
add address-pool=default-dhcp interface=ether1-local name=default
/tool user-manager customer
set admin access=\
    own-routers,own-users,own-profiles,own-limits,config-payment-gw
add bridge=bridge1 interface=wlan1-gateway
add bridge=bridge1 interface=ether1-local
add address=192.168.88.1/24 comment="default configuration" disabled=yes \
    interface=ether1-local network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=\
    no interface=bridge1
add address=192.168.88.0/24 comment="default configuration" gateway=\
    192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=\
    established,related
# in/out-interface matcher not possible when interface (wlan1-gateway) is slav
    use master instead (bridge1)
add action=drop chain=input comment="default configuration" in-interface=\
    wlan1-gateway
add chain=forward comment="default configuration" connection-state=\
    established,related
add action=drop chain=forward comment="default configuration" \
    connection-state=invalid
    connection-nat-state=!dstnat connection-state=new in-interface=\
    wlan1-gateway
add action=masquerade chain=srcnat comment="default configuration" disabled=\
    yes out-interface=wlan1-gateway
Client
add mtu=1500 name=bridge1
/interface wireless
    20/40mhz-ht-above country=norway disabled=no l2mtu=2290 mode=\
    station-bridge name=wlan1-gateway nv2-cell-radius=10 ssid=MikroTik \
    wireless-protocol=nv2-nstreme-802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=\
    tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
    unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=lollollol \
    wpa2-pre-shared-key=lollollol
add address=192.168.1.89/24 comment="default configuration" interface=\
    ether1-local network=192.168.1.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=\
    bridge1
add address=192.168.88.0/24 comment="default configuration" dns-server=\
    192.168.88.1 gateway=192.168.88.1 netmask=24
/ip dns static
add address=192.168.1.89 name=router
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
    wlan1-gateway
    established
add chain=forward comment="default configuration" connection-state=related
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/romon port
add disabled=no
/system clock
set time-zone-autodetect=no
/system identity
set name=client1
/system leds
set 0 interface=wlan1-gateway
/tool mac-server
add interface=ether1-local
/tool mac-server mac-winbox
The client wont connect it status windows says: searching network
pukkita
Trainer
Trainer
Re: bridge problem
Mon May 25, 2015 4:58 pm
Nv2 uses its own security.
You're missing
in the station-bridge radio.
then do a scan and connect to the other radio.
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
patrick7
Re: bridge problem
Mon May 25, 2015 5:21 pm
You should always add IP addresses to the bridge interface, not to ether1 inside the bridge.
Thalid
Re: bridge problem
Mon May 25, 2015 9:45 pm
Did the trick :D
Not shure why i had to add it under wireless->interface name->nv2 tab when i allready entered the pre shared key in the quick set.... when i choised what wireless that i wanted to connect to..
used this guide so guess its wrong then
http://www.ispsupplies.com/content/reso ... Bridge.pdf
pukkita
Trainer
Trainer
Re: bridge problem
Mon May 25, 2015 11:10 pm
Radios can use regular 802.11, nstreme or NV2; NV2 uses its own security, what you setup (WPA) is for 802.11 mode.
You should also follow Patrick7 advice, when assigning IPs to bridge devices you should add it to the bridge itself, not any of the interfaces on it.
Users browsing this forum: Baidu [Spider], Bambie, cknolla, digin4, sindy, zerospace and 59 guests
