MUM Europe 2020
justlovingIT
Port isolation on CRS + limiting outbound
Mon Jun 01, 2015 1:30 pm
Hi guys,
I've just deployed a CRS125 to a new rack and ran into some issues. Being used to stock switches and doing network-engineering stuff only ocassionally it took me quite some time to get things settled :-D
I've got the following setup
/interface> ethernet print
Flags: X - disabled, R - running, S - slave
 #    NAME                          MTU  MAC-ADDRESS       ARP        MASTER-PORT            SWITCH
 0 R  ether01-WAN            1500 4C:5E:XX          enabled        none                          switch1
 1 RS ether02-srv              1500 4C:5E:XX          enabled        ether01-WAN            switch1
 2  S ether03-srv                1500 4C:5E:XX          enabled        ether01-WAN            switch1
 3 RS ether04-srv              1500 4C:5E:XX          enabled         ether01-WAN            switch1
10  S ether11-srv               1500 4C:5E:XX          enabled         ether01-WAN            switch1
11 R  ether12-priv-master 1500 4C:5E:XX          enabled         none                          switch1
12  S ether13-priv               1500 4C:5E:XX         enabled      ether12-priv-master    switch1
ether1 is the DC Uplink
Ports 2-11 (NET) get public addresses from the range 78.xx.yy.zz/27
Ports 12-24 (LAN) got the private range 10.10.0.1/24 with PPP (openVPN) for remote access
I want to do the following:
a) Is there a way to simply limit internet access to specific ports on the private network (LAN ports: 12-24) without VLAN configuration (not required here). At the moment the ports can reach the net via 10.10.0.1. The point is that at least one port needs internet access (NAS) for software updates and warning mails while I don't want the rest to reach the net.
b) I'd like to enable port isolation on ports 2-11 (NET) so that the hosts there can only reach the gateway. I assume that port isolation will require a VLAN config then. What is the most simple way to set this up for the few hosts on that segment?
chechito
Re: Port isolation on CRS + limiting outbound
Mon Jun 01, 2015 4:54 pm
i allready answered on the another topic you created for the same issue
please do not do multiple topics for the same thing
justlovingIT
Mon Jun 01, 2015 5:26 pm
I'm sorry but the othe rtopic you're referring to was about a strange reading I noticed in webfig.
I don't think that: do everything with VLANs does answer the questions a) and b) in this topic.
pukkita
Trainer
Trainer
Mon Jun 01, 2015 6:12 pm
a) With firewall filter rules or...
b) Port isolation, see the wiki
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
Users browsing this forum: MSN [Bot] and 58 guests
