intouch
RB951G-2HnD Drops wi-fi connections
Mon Jun 01, 2015 5:29 pm
Hi everybody!
We've bought Mikrotik RB951G-2HnD in our company (about 20 - 25 clients in network) with 50 Mbps channel from the ISP-side.
Mikrotik Wireless drops connection from time to time as often as more people are connected via Wi-Fi:
The current configuration is following:
What point should we start to diagnose and solve this problem?
Thank you!
leaseitc
Re: RB951G-2HnD Drops wi-fi connections
Wed Dec 30, 2015 5:18 am
I'm having the same issues. My connection from my ISP isn't nearly as high though. As my Wi-Fi gets over 25 users, other machines start disconnecting. I am also using a RB951G-2HnD with RouterOS 6.33.2.
flameproof
Wed Dec 30, 2015 11:10 pm
Make sure your DHCP pool isn't being exhausted - are these always the same clients? Otherwise, you could have leases out to clients no longer connected. If this is the case, decrease the lease time, or use a script to remove the lease upon disassociation from the wireless side.
Pea
Thu Dec 31, 2015 1:03 am
Also check what is your setup under /interface wireless max-station-count
freemannnn
Long time Member
Long time Member
Fri Jan 01, 2016 4:55 pm
Use channel width only 20mhz and not 20/40.
try with wmm disable. The setting appear when u press advance button.
Security use only wpa2 aes and not tkip.
Which package you use? Wireless-cm2 or wireless-fp?
Users browsing this forum: arkos, mohkhalifa, ranjeet9393, xiaotuzi and 161 guests
