igb
Unusable: 6.29.1 has similar memory leak to 6.28
Tue Jun 02, 2015 10:27 pm
Here is the memory use on my 2011UiAS under 6.27 over the past month and the state it ended up in 11 minutes after restarting on 6.29.1, moments before the router restarted, 100% CPU, memory almost exhausted.
When I installed 6.28 it ran for a few minutes before watchdog-ing because of memory exhaustion, showing the same symptoms.
6.29.1 is also broken: it runs for a few minutes leaking memory slowly, and then suddenly leaks memory (dropping for 95MB free to 7MB free in about 30 seconds) and restarts.
Surely this needs to be fixed?
chechito
Re: Unusable: 6.29.1 has similar memory leak to 6.28
Wed Jun 03, 2015 3:58 am
im using 6.29 on rb951Ui and rb 951G without issues
maybe specific problem on rb2011??
sam1275
Thu Jun 11, 2015 3:30 pm
Hi.
I'm using RB2011UiAS-2HnD with 6.29.1, no problem at all...
lz1dsb
Thu Jun 11, 2015 3:59 pm
I'm using 6.29.1 on both RB951Ui and RB951G - no issues at all. It must be a something specific...
macgaiver
Thu Jun 11, 2015 4:05 pm
My uptime is too small to observe, i'm testing new RC like crazy :)
, but you need to write to support@mikrotik.com with two supouts. one just after the reboot, other one from situation like in picture. both must be the uptime period.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
kei888
Sat Jun 20, 2015 1:25 pm
Hi! I have RB951G-2HnD router w/ 6.29.1 firmware installed.
Just 10 minutes ago, my router rebooted automatically and upon checking the logs, found this issue:
Users browsing this forum: altermeinhausbrennt, jebz, robertkjonesjr, sfrode and 51 guests
