timk
IPSec VTI
Tue Jun 09, 2015 4:14 pm
Please can IPSec VTI be considered for RouterOS v7?
The Linux kernel has had support since 2012:
http://git.kernel.org/cgit/linux/kernel ... c617c68059
I know the same can be done manually with IPSec+GRE but it is a huge deal with larger installs and one is more prone to making mistakes.
Cheers
nz_monkey
Re: IPSec VTI
Wed Jun 10, 2015 5:14 am
This has been requested countless times.
See http://forum.mikrotik.com/viewtopic.php?f=2&t=65734
Mikrotik MTCNA, MTCRE, MTCINE
http://thebrotherswisp.com/
timk
Re: IPSec VTI
Wed Jun 10, 2015 8:35 am
Thanks, I must have a bad memory, I had even posted in that thread! :shock:
aigarslv
Re: IPSec VTI
Fri Jun 12, 2015 5:22 pm
I also would like to see this feature. Also it would be good to be able to create Virtual Interfaces in general (as you can in Linux) and not only for MetaRouters or KVM.
nz_monkey
Re: IPSec VTI
Mon Jun 15, 2015 1:16 pm
Ha ha.
Hopefully Mikrotik have not forgotten this request :)
Arcticfox
Re: IPSec VTI
Fri Nov 15, 2019 8:40 pm
2019 AD, November 15, Strongswan have a stable implementation of VTI...
Request still pending.
valsily
Re: IPSec VTI
Mon Nov 18, 2019 4:23 am
Bump. We need VTI support!
dnordenberg
Re: IPSec VTI
Mon Dec 02, 2019 8:18 pm
Yes, VTI support please, policy tunneling is not very user friendly to setup, I rather use traditional routing.
bluecrow76
Re: IPSec VTI
Thu Apr 01, 2021 3:09 am
Not to mention that this would allow interop with many other router vendors IPSEC VTI based tunneling solutions.
mducharme
Trainer
Trainer
Re: IPSec VTI
Thu Apr 01, 2021 3:13 am
They are adding VTI is my understanding. I think the issue probably is if they add it now, while RouterOS v6 is still being updated, it is much more work for them to manage both code bases because the RouterOS v7 ipsec code will diverge from the RouterOS v6 ipsec code making it a lot harder to keep the code bases in sync with the same fixes. So they are likely waiting until RouterOS v7 stable comes out before they add this, as at that point, they will no longer need to make updates to RouterOS v6 as frequently.
dnordenberg
Re: IPSec VTI
Thu Apr 01, 2021 9:05 am
Ehm, I could be wrong here but my understanding is that VTIs are purely a local thing, the tunnel or other end does not know about if VTI is used or not at the opposite end. VTI should allow you to add a virtual interface in a hw/L2 like manner but will still only pass L3 traffic. Just as the policies. Policies vs VTI/routing is just cosmetic, both will do the same but in different configuration ways.
doneware
Trainer
Trainer
Re: IPSec VTI
Tue May 18, 2021 3:20 pm
yes and no. it has to support also multicast transport (for OSPF to work) which is not possible with policies.
also the encapsulation is different, consider the figure below.
#TR0359
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 41 guests
