w0lt
RouterOS 6.30rc17
Thu Jun 11, 2015 4:54 pm
As with RouterOS 6.30rc13, the current beta release 6.30rc17 (SMIPS) does not have a wireless driver in the "All Architectures" zip package.
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
honzam
Re: RouterOS 6.30rc17
Fri Jun 12, 2015 9:23 am
LAN, FTTx, Wireless. ISP operator
normis
Fri Jun 12, 2015 9:48 am
yes
eworm
Fri Jun 12, 2015 3:00 pm
*) ssh - added option '/ip ssh stong-crypto'
I suppose this should read strong-crypto, no? What exactly does this change?
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
janisk
Fri Jun 12, 2015 3:19 pm
it makes SSH connections more secure. SHA256 instead of SHA1 and MD5 is kicked out, longer DH, cipher-less connections are not allowed (one where you set cihpers=none) and stronger ciphers are preferred by the ssh server.
makes your SSH connection to the router slower :) due to better encryption. As most users do not require this (like managing routers from local area network) then old settings are deemed to have adequate security. Those that require higher security now can have it.
p.s. it is called '/ ip ssh strong-crypto' there is a typo in the changelog.
eworm
Fri Jun 12, 2015 3:24 pm
makes your SSH connection to the router slower :) and slower due to better encryption. As most users do not require this (like managing routers from local area network) then old settings are deemed to have adequate security. Those that require higher security now can have an option to have it.
p.s. yes it is called '/ ip ssh strong-crypto' there is a type in the changelog.
Ah, really nice! Thanks! :D
Looks like this still does not bring suppport for RSA (or even ed25519), though.
janisk
Fri Jun 12, 2015 3:43 pm
RSA and for that matter ed25519 is not just a matter of flip-a-switch to enable them. We have to actually implement it. RSA currently is accepted as a feature request. Is not of a high priority.
eworm
Wed Jul 01, 2015 9:10 am
Just a quick heads-up on this topic. OpenSSH 6.9 has been released. The announcement lists some features that will be run-time disabled by default with the release of OpenSSH 7.0 in July:
* Support for ssh-dss, ssh-dss-cert-* host and user keys will be run-time disabled by default.
You will still be able to enable it, but the default configuration will fail with RouterOS devices.
rpr
Fri Jul 10, 2015 8:08 pm
On v. 6.30 I've tried to run that command but it gives an error:
> /ip ssh strong-crypto
bad command name strong-crypto (line 1 column 9)
I have the following packages enabled: advanced-tools, routeros-mipsbe, routing, security, system.
What could be the problem?
-- rpr.
grusu
Sat Jul 11, 2015 12:17 am
/ip ssh set strong-crypto
rpr
Sun Jul 12, 2015 12:54 am
I'm still getting an error:
> /system identity export
# jul/11/2015 23:49:35 by RouterOS 6.30
# software id = JLR6-SIQJ
/system identity
set name=gw.example.com
> /ip ssh set ?
Change properties of one or several items.
always-allow-password-login -- allow password login when public key authorization is configured
forwarding-enabled -- allows clients to connect to remote ports from server
strong-crypto -- use stronger encryption, HMAC algorithms, use bigger DH primes and disallow weaker ones
expected end of command (line 1 column 13)
eworm
Mon Jul 20, 2015 9:51 am
Changes have been committed to git. Current development version can not connect to RouterOS devices:
% git describe
V_6_9_P1-32-gd56fd18
% ./ssh host
ssh_dispatch_run_fatal: Connection to XX.XX.XX.XX: no matching host key type found
eworm
Thu Jul 30, 2015 1:49 pm
Starting with RouterOS 6.31rc10 we have support for RSA keys! Thanks a lot Mikrotik!
Users browsing this forum: No registered users and 85 guests
