sdischer
Trainer
Trainer
More MikroTIk HowTo's
Sat Jun 20, 2015 2:36 am
I have posted a few MikroTik HowTo's on my blog:
RoMON
http://stevedischer.com/mikrotik-romon- ... -routeros/
Another Way to do Automatic Failover with MikroTik RouterOS
http://stevedischer.com/another-way-to- ... -routeros/
Improve MikroTik CAPsMAN Roaming Performance
http://stevedischer.com/improve-mikroti ... rformance/
DHCP Option 43 on MikroTik
http://stevedischer.com/dhcp-option-43- ... os-ruckus/
MikroTik Wireless CAPsMAN Howto
http://stevedischer.com/mikrotik-wirele ... man-howto/
I hope you find them useful. Good luck!
Steve Discher
http://ISPSupplies.com
http://LearnMikroTik.com
Steve Discher
LearnMikroTik.com, USA
RouterOS Training and Consulting
Get Certified!
http://www.LearnMikroTik.com
jebz
Re: More MikroTIk HowTo's
Sat Jun 20, 2015 3:55 am
RoMON
Steve Discher
Thankyou Steve for sharing.
A revision for your RoMON how-to
"RouterOS since version 6.38" should be v6.28?
Bigfoot
Mon Jul 06, 2015 12:07 am
Hi Steve
I can not enter you blog getting "Connection timed out".
Bigfoot
jaytcsd
Fri Jul 10, 2015 11:58 am
found a few typos
MikroTik RoMON Feature Added to RouterOS
"I have sen some instability"
These are the ones I talked to you about a few weeks ago.
"Please not you must set up your email server IP,"
This confuses me, I think you mean you set Provider1.
"When pings return, it sets the distance on the default route through PROVIDER2 back to 1 making it the active route"
Users browsing this forum: msatter and 93 guests
